Question about Vehicle Parts & Accessories
Alarm needs to be reset
The battery in our toyota went dead. the alarm system needs to be reset and im not sure how. can you help?
    President:
  • 1,509 Answers
Many cars, Maybe not yours can be tricked into thinking that they've never been tripped to begin with. This procedure needs to be done carefully as inpresicsness can mess the car up. With the battery fully charged. ( not jumped, ran the car for awhile, Charged, the battery charger says so) and the cables clean ( they don't just look clean, cause you cleaned them anyway) disconnect the battery and come back later ( 10 MInutes ) Connect the cables to each other ( not the battery ) Hold em there ( 1 Minute ) Connect the positive and let the neg hang free. Turn the key to the run position. everything else off. Connect the neg cable like you mean it ( don't bump it skip it fool with it, Get it on tight in one move). Start the car. The security system never knew it was off and it'll start as if it were already on. Being you didn't tell what kind or year of car or truck you have it'll work on most and it won't hurt the others. It's hard to fix vehicals with out knowing the year model as the rules change with each model year.
Posted on Sep 19, 2009
If driven with alarm sounding when battery replaced in key will it run funny
It surely can and will. Most likely all you need to do is have the codes erased.
Jul 24, 2015 | 2007 Toyota RAV4
Reset factory alarm on a toyota avalon xls 1996
If the alarm system has a battery remove it otherwise removing the car battery for a while may reset it. In emergency contact your local toyota dealers mechanics department and they may be able to help you at no cost.
If you put a general enquiry on google you might get lucky, do not be too specific. i.e. toyota 1994 alarm reset procedure
Sep 19, 2014 | 1996 Toyota Avalon
The alarm went off for a long period of time now remote battery went dead and system wont activate
No, a car alarm will not go off if the car alarm is dead. -------------------------------------------------------------------------------
FGTECH Adapters
Dec 21, 2012 | 1999 Toyota Corolla
Hello I hope you can help me. I have a 2002 Toyota Sienna Van. Park van - was running great. Snow came, let van sit one day. following day tried to start van. Van will not start, closed the door and...
some will reset by locking and unlocking the door with the key.....or .need to replace the battery in the car it is dead and when u try to reset it trips again because it is dead
Nov 27, 2010 | 2002 Toyota Sienna
The battery went dead. When charging the battery
Disconnect the fuse for the alarm system or unplug horn relay system to change battery if you unplug fuse you will have to reset the alarm, be sure you know how to do this before disconnecting the fuse to the alarm system. Hope this helps.
Feb 23, 2010 | 2004 Infiniti I35
Car sat for six months. Battery went dead and replaced with new one. Got it started after new battery, now it won't start, the alarm led is either flashing bright or very dim flashing fast. I'm sure that...
When alarm goes off,put key in ignition and turn,the alarm should go off and alarm should be reset.Or,remove positive battery cable,wait 10 minutes,reconnect,when you open door,alarm will sound,insert key in ignition and turn key and alarm should go off and alarm should be reset.
Aug 14, 2017 | 1994 Toyota 4Runner
Toyota Camry 1994 No ignition think it may be alarm
disconnect the alarm system from under the dash.battery to starter direct will turn the engine over fine but ignition system still runs through your alarm system.It's also a theft prevent system so your car will not be stolen.The alarm went bad preventing your car from starting.That means putting the ignition wiring back to factory.
May 25, 2009 | 1994 Toyota Camry
1993 Toyota Pickup Alarm
Glad to be of service. The graciousness of a FIxYa rating would be most appreciated.
Dec 10, 2008 | 1993 Toyota Pickup
98 celica battery went dead replaced now it want crank
Try this: Unhook the battery. Reconnect the battery. When the horn starts to beep, cycle the ignition key in the ignition on-off 5 times. This resets the alarm; the cycling of the key. Please advise me if this works for you.
Oct 07, 2008 | 1998 Toyota Celica
Vehicle Parts & Accessories Logo
244 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
