Acts like it will not stay powered on. Blue power light blinks, the screen flashes and then everything goes dark. Repeats every 3-5 seconds.
  • 1,684 Answers
You have a very common problem with LCD monitors that are 2-3 years old. Because of heat buildup in the case parts called capacitors will blow causing the power supply to fail. If you can solder you should be able to repair it yourself. Go to our web page at :
www.ccl-la.com/badcaps.htm and look at the pictures of failed capacitors. Open you monitor and replace any that look like the pictures on the site. Be sure to install the new ones with the stripe on the side going the same way as the one you pull out and use a high temp replacement. You will see the values on the side of the parts you take out. Replacement caps can be ordered from us or other places on the internet. If you don't want to try the repair yourself we can do it for $35 + return shipping.
I hope this helps, If so please rate r solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 11, 2009
Testimonial: "Thanks a bunch.I'll give it a shot. "
Blinking green light
It is likely that the power supply is failing. It tries to start and powers up briefly then shuts down.
Oct 28, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blinking heart beat led blinking
When the following situations, you need to replace the LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/compaq-presario-cq40533tx-lcd-inverter-p-2632.html
May 24, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
HP IQ 526 When I press the power button the backlights flash and the power led goes yellow after a few seconds the screen flashes again and the fans restart then it just stays dark, if I hold the power...
Hi Jerry,
Do follow the steps below...
1. Remove the RAM from the motherboard and switch it on. (you'll get 6 continuos beeps) Refix the RAM and check whether it is working or not...
2. Remove the CMOS battery and switch on the PC_ Switch off_Re fix the battery to the slot_Switch on...
3. Disconnect the hard disk from the PC and switch it on...
May 21, 2012 | HP TOUCHSMART IQ526 PC PC Desktop
A message flashes at the bottom of the screen
tv is overheating.  possible that fan not working or temperature protection circuit faulty.  check fan for excessive dirt first.  could be as simple as cleaning the fan
Jul 29, 2010 | Mitsubishi WD-57731 57" Projection HDTV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Oct 14, 2008 | Westinghouse SK-32H240S Television
Problem with monitor
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
It sounds like you have bad capacitors on your powerboard or possibly a burned out transistor on the inverter.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
There is a chance one of your bulbs is creating a problem
Should the screen happen to light up all white, then your power board and inverter are okay and the problem may be in the video board.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
If it flashes on then goes off, it's in the power or inverter board.
ebaysbammbammfran
Sep 14, 2008 | ViewSonic VX2235wm LCD Monitor
Flm-3201
my polaroid model #3200  does'nt come on!  the light goes from red to blue and nothing,the picture stays black with no flashing or flickering
Apr 01, 2008 | Polaroid FLM-3201 Television
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Computers & Internet Logo
206 people viewed this question
David Payne
David Payne
