Question about Toshiba (SD-C2302) DVD Drive
Toshiba DVD-ROM SD-C2302 will not burn
My DVD plays CD's just fine. However, I can't backup my files to CD. Windows 2000 says that the CD can't be formatted. Two different software burners say that the DVD drive cannot be written to.
  • laneycomo27 Apr 04, 2009
    TOSHIBA DVD-ROM SD- C2302 WILL NOT BURN MY CDS
I have the same model and it's not a burner
Posted on Jan 07, 2008
Will burn cd-r but kicks the disk out whe I put in a blank DVD-r
Sorry but your burner is a CD-RW/DVD-ROM
this means you can burn CDs and play DVD
you cannot Burn DVD with this device.
info link here
http://www.cdrinfo.com/Sections/News/Details.aspx?NewsId=7470
Please don't forget to rate me : )
Oct 01, 2009 | Toshiba SD R1312 CD-RW/DVD-ROM Burner
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
I have a IBM 600E laptop. Changed my CD rom reader to DVD rom. Can't play DVD on this. Says DVD driver missing. The hardware is a Toshiba DVD-ROM SD-C2302 reader. Where can I get driver to be able to play...
just go to www.driverguide.com signup there, after you signup, login with your correct username and password. After you login, click manufacturers, click letter t, find toshiba and click it. after the you click it, you are redirected to another page. If you see the search for company drivers search box, enter your the model and number of your hardware which is the dvd rom. and follow the instructions given by that site to download your driver
Jan 17, 2009 | Computers & Internet
I need install CD/RW-DVD Model GCC-4243N in Tecra 8100 PT810C-11C52, but in screen show error# IDE1 Bios is Version 2.10, maybe I need upgrade Bios?. The CD Rom old is an SD-C2302. Thank for your help,...
Yeah... that's common. The Toshiba DVD drives uses a different drive select than other people's DVD drives. Look to the manufacturer of your DVD/CDRW drive and look to see if there's a firmware update that will allow you to set the drive select differently. If not, then you'll be stuck with the IDE1 thing forever.
Now... here's the fun part: some of these drives will give you an IDE error, they'll never boot, but some of them will work perfectly when you get into Windows.
Aug 02, 2008 | Toshiba Tecra 8100 Notebook
Toshiba DVD ROM SD M1302 driver
If you are using Windows 98, 98SE, ME, 2000, NT or XP, and have an ATAPI/IDE CD/DVD drive, there is no driver needed (see Toshiba statement I have posted below). Under no circumstances, if DVD is properly installed and functional, will you need ANY driver!
If your DVD drive is a SCSI drive, then it may need drivers specific to the SCSI card you have installed (see the specs/manual or website for your card). You may also need the Adaptec SCSI setup, available at this address:
http://www.adaptec.com/worldwide/support/suppbyproduct.jsp?sess=no&language=English+US&cat=%2FTechnology%2FSCSI+Software&fromPage=driverindex
or use this address if you have a LOGIC based SCSI card or device:
http://www.lsilogic.com/
Now, if you meet the criteria for the first paragraph I wrote, and your PC does not load the driver automatically (after a reboot or two) then you have a PHYSICAL or HARDWARE problem. Either the DVD drive is improperly cabled, improperly installed or defective.
Those are all your options. See below, from Toshiba website
good luck
http://sdd.toshiba.com/main.aspx?Path=ServicesSupport/DeviceDrivers
ATAPI CD-ROM and DVD Drivers
Toshiba's CD-ROM and DVD-ROM drives do not require any unique device drivers for Windows '95/'98/2000/XP/NT.
After installing your drive and re-booting, your system should recognize your CD-ROM or DVD-ROM. Win '95/'98/2000/XP/NT Operating Systems support all Toshiba ATAPI CD-ROM and DVD-ROM drives natively.
DOS/Windows 3.x Device Drivers
This device driver is to be used with DOS/Windows 3.x operating systems. Do not use this driver with Windows '95, Windows '98, XP or Windows 2000 unless you are going to use your system in the REAL or MS-DOS Modes. Device drivers for Windows '95, Windows '98, Windows 2000, XP, OS/2, and NT operating systems are provided with the installation or setup software of each operating system.
DOS ATAPI Interface Driver
If you prefer using DOS click the link below to download a MS-DOS ATAPI interface driver.
atapi.exe
SCSI CD-ROM and DVD Drivers
SCSI interface drivers are written for the SCSI card you are using in your system, by the SCSI card manufacturer. They are not specific to your Toshiba drive and are not provided by Toshiba. If during installation Windows can not find the correct SCSI software driver for your SCSI card and you do not have the software driver that came with your SCSI card, contact your SCSI host adapter manufacturer.
Adaptec SCSI Drivers
LSI Logic (Symbios) SCSI Drivers
DVD Viewing Software
Toshibas DVD drives require a third party software to be installed in your system to enable you to view DVD movies. If you purchased your drive as part of a kit, the software may have been included. The links below will provide some possible solutions should you not have this type of software.
Nero6 (Toshiba recommends)
Toshiba does not recommend nor endorse any of the following manufacturers software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
DirectDVD
Cyberlink PowerDVD
WinDVD
Media Burning Software
Toshiba's recordable drives require third party software to be installed in your system to enable you to burn media. If you purchased your drive as part of a kit, the software may have been included. The link below will provide some possible solutions should you not have this type of software.
Toshiba does not recommend nor endorse any of the following manufactures software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
NTI CD & DVD Maker
Gear DVD & CD-RW
Roxio Toast (Macintosh)
Easy CD Creator
Stomp Clinkn Burn Pro
Feb 24, 2008 | Computers & Internet
Toshiba SD R2132 CD-RW/DVD ROM
Your CD "Burn" laser or "Quadrant Detector" has "Faulted" a very common occurrence for these "Combo" drives,...So..I'm sorry but ya gonna haveta get another... as these ya can't fix. :(
Sep 18, 2007 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
241 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
