Question about Mtd Products Yard Machines 158CC Tiller
Grass comes out both sides of mower deck.
I just cleaned my 38" MTD riding mower and now grass comes out both sides of the mower deck. Most of the grass goes out the normal chute but it has started leaving strips of cut grass on the opposite side of the deck as well. Would this have anything to do with the position of the blades? I did try to remove the blades and was unsuccessful and perhaps moved them out of position. Anyone have any suggestions?
  • 157 Answers
Yes you need to check the blades
Posted on Sep 18, 2009
Mower deck adjustment ride on mower MTD 13538 cutting deck a lot lower than rear of the deck shaving the grass to dirt.
Are all the rods that hold the deck on all the same length. Has any been replaced with the wrong ones. Did this machine hit something that things were bent an out of shape.
Are your tires blown up where they should be? Soft tires will do that.
Dec 07, 2016 | Mtd Garden
Where on the deck do i install the 490-900-0025 MTD Riding Lawn Mower Deck Wash Kit
IMHO,. this is not worth installing, I have one on my Husquavarna ,and it broke off ....I'm NOT putting in back on,a good scraping of the grass is easier,and the bearings don't see all that water !
Jun 18, 2014 | Yard Machines MTD Riding Mower Deck Wash...
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a poulan 38" mower. Something seems to be wrong with the deck. The left side cuts great, but not the right. The right side seems to beat the grass into submission. If I back up over the same path I...
check mower blades for blade upside down. you may be hitting grass with back of blade. match blade position to working blade side. or swap blades left to right and see if problem moves. if so, blade is culprit. also cold be a loose blade bolt allowing the shaft to spin without driving the blade. Do all work with engine off key out!
May 16, 2013 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I need a diagram for deck belt on a 1989 lawn boy lt 12 38 " deck
it's usually on top of the deck clean off the grass and look on top may have to remove it to see
Oct 19, 2012 | Mtd LAWN MOWER PART # 983-04052 DECK...
Wierd grass catcher problem
There are a couple of causes for this. Is the blade height the same on the new mower? Higher blade height could cause a lot of the grass to be blown out from under the deck, and not into the catcher chute.
On the trailing edge of the mower blades is a small 'wing' for lack of a better term. There are two types of blades, mulching blades that have a lower 'wing', while catcher blades that have a slightly higher 'wing' but it makes a difference.
If the season has been hot lately, the grass may not be growing as fast, hence less clippings, and less dense grass could also cause this.
Jun 16, 2012 | Mtd Garden
I have a mtd yard man 22inch / mulcher . My question is how do I get the mower to start mulching ?
For mowers like yours, there are straight cut discharge blades (for bagging the grass) and there are more expensive upswept mulching blades. Any holes in the sides of the deck must be covered to mulch as the blade keeps the grass up in the air under the deck, repeatedly cutting it...over and over..till it falls on the ground.So use a solid deck with the upswept type blade.
Aug 31, 2010 | Mtd 22" Yard Machine Push Mower
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Weedeater 12.5 hp 38
thats a ayp deck.
the 38 and the 42 take the same belt
Aug 29, 2008 | Garden
Mtd Products  Yard Machines  158CC Tiller Logo
150 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
