Question about Lakewood HV12WR Window Mount Fan
Lakewood window fan 7 position switch.
First try the following link for switch.
http://www.nelsonappliance.com/Lakewood+Fan+Switch+for+HV18WR+%28Window+Fan%29.html
I need a wiring diagram to tell which wires go to which connections on the switch. Did not write them down before taking switch off. Also you might try the following link also:
http://www.dnagroup.com/cgi-bin/view_services.cgi?request=detail&prod_num=DYE&aisle_id=3
you will have to contact their local rep.
4 Suggested Answers
  • 52 Answers
SOURCE: need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Posted on May 29, 2009
SOURCE: Window Fan switch bad
Try the following links for the switch you need:
I have the same problem. I have a new switch but I need the wiring diagram to know which wire goes to which connection on the switch. If you have the diagram please contact me via email. qwazy@centurytel.net
Posted on Sep 11, 2009
  • 6 Answers
SOURCE: Lakewood HV18WR Window Fan is there a fuse in this
Yes look at the back of it and u should see some engraved writing of the fuse. buy this
Posted on Oct 01, 2011
Since Lakewood doesn't make fans any longer, any idea where I could pick up a couple of their 9-inch high velocity fans (new or used)?
Hi randy r metc...
I found one 9" High Velocity fan on ebay, it is new at a cost of $19.99 and free shipping.
Please take time to rate me
To see the fan go to the following webpage
http://www.ebay.com/itm/Lakewood-9-High-Velocity-Fan-1016-/320745163838?pt=LH_DefaultDomain_0&hash=item4aade6cc3e
Aug 18, 2011 | Lakewood High Velocity Fan 9 Inch
Switch broken
May not be identical but an appliance store or hardware store should be able to assist you with that. Home depot or Lowes as well. Take old one with you if you can.
Jul 10, 2010 | Lakewood 200I Floor / Box Fan
Lakewood heater 792 will not work
The bottom switch is bad. Unplug bottom wires and touch them together, if heat and fan comes on your switch is bad.
Feb 11, 2010 | Lakewood 792/JR Utility Heater
No power getting to my Lakewood fan...
Maybe you tripped over it so hard you de soldered the wires form the inside. Have you openned it? Try it out if you didn't. Check the power cord and follow it all the way into the motor (with the motor openned). Check if one or both cables on the inside are desoldered.
May 09, 2009 | Lakewood HV 18-c Floor / Box Fan
Lakewood HV-18 fan... how to wire switch?
My switch unit also fell apart as I took the back off and I didn't get to see the correct position of the switch. After much trial and error, I found this to be the initial "Off" position (see photo)
Oct 13, 2007 | Lakewood HV 18-c Floor / Box Fan
Steve, Your fan model is HV-18-WR; I have 2 with the same problem. I can't find a source for DYE-3606 switches either. Here is one source for rotary switches; one might be suitable: http://www.alliedelec.com/Catalog/Indices/Products.asp?sid=46BBAA8076DBE17F&N=4294828748 I can draw a diagram of how the existing switch is connected, but I don't know how that would translate to a replacement switch.
May 22, 2007 | Lakewood HV12WR Window Mount Fan
Lakewood HV12WR Window Mount Fan Logo
138 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
