Question about Samsung LN-S4041D 40 in. LCD HDTV
TV turns on and off repeatedly when connected to power
Never successfully turns on again.
The exact model is LE40R81B.
Its still in warranty but I'd like to fix it without waiting for technician :-)
Thanks!
    Genius:
  • Samsung Master
  • 1,039 Answers
Be aware that if you tamper with the set you will void your warranty. Check power board for swollen capacitors. I would wait on auth Samsung serv tech.
Posted on Sep 12, 2009
What does it mean when the standby light flashes four times on a Sony TV Model # KV-24FV12 ?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 22, 2014 | Televison & Video
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
My RCA Model F36690BCYXI tv will not power up. When the power button(or remote) is pushed the tv just clicks repeatedly but will not turn on.
The internal power supply on your tv has died. This can be an expensive replacement, if this tv is still under warranty, you should get a replacement.
May 09, 2011 | Televison & Video
My television blinks all the time, it turns black for a second, then shows the channel again for a second and repeats this pattern all the time. I've tested other inputs (scarts) and it is the same thing...
It sounds like the backlight of your television is about to go completely out. If you are under your manufacturer's warranty; they can set you up for a replacement or a work order with one of their contracted facilities. If not take it to your local repairman but try to get a parts request email or phone number from your man. rep. for your repairman
Aug 05, 2009 | Televison & Video
Sony TV (2003) 60 inch....Picture come in and out.
I do no have exact model number of your Sony TV so if it is DLP TV (lamp inside) then it is symptoms of weak lamp that will be replaced.
Let me know model number to help you out with exact info.
Mar 28, 2009 | Sony Televison & Video
Sudden power failure
my swisstec tv had exactly the same problem this week march 30th and the 12 month warranty expired.....i went to skymediauk online and extended my warranty ..free for 3 months they collected it,fixed it and returned it in 46 hours
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Samsung LN-S4041D 40 in. LCD HDTV Logo
283 people viewed this question
Henry  Thomas
Henry Thomas
