Question about Dell Photo 964 All-In-One InkJet Printer
Every few lines of print there is a thin white line that shows up in the middle of the line of print, and below the white line the lower portion of the letters look okay but above the white line the upper portions of the letters are offset slightly and look like they are in italics. This happens about every 10-12 lines of print. Does something need to be cleaned on the ink nozzles or how can I repair this?
  • johncall5771 Sep 11, 2009
    I have already tried the deep cleaning procedure a couple of times and it has not helped.
    Brigadier General:
  • 4,044 Answers
Go throught he maintenance menu and perform a Deep cleaning of the printer nozzles. This will use a lot of ink so use your current cartridge to do this. Once teh cleaning cycle is complete, replace teh cartridge and align the heads with the maintenance menu selction.
Posted on Sep 11, 2009
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
There are two very thin lines (pixel thin) that just appeared on the LCD screen. One is in the middle near the bottom, the other is on the lower left side. They are both fixed and are there no mater which...
If these lines are white, then they generally are a line of burnt out pixels. There is no home fix for these and I have yet to see a repairman fix this problem. I have seen on occasion where the line gets longer. Its best to start looking for a new replacement or try to live with it until you can't stand it any more.
May 15, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Lines on prints
usually happens when the printer drum wears out and could use replacing in my experience
Brentwood IT
Sep 21, 2009 | HP Office Equipment & Supplies
Prints faint and cuts of the top and bottom of some lines
The ink in the cartridges has dried up. Replace them.
Feb 01, 2009 | HP DeskJet 950c InkJet Printer
EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
Jan 12, 2008 | Epson Stylus CX3810 All-In-One InkJet...
No Picture
If the thin white line you mention is crossing the screen from left to right, your tv is experiencing what is called "vertical collapse". That is a very common problem that is repairable and may be as simple as a few solder connections to replacement of the vertical output IC and a few capacitors. If you can find a qualified shop, take it in and it shouldn't cost much more than $100 to get it fixed.
Dec 21, 2007 | Sanyo HT32744 32" TV
HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Sep 09, 2007 | HP Color LaserJet 2600n Printer
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Dell Photo 964 All-In-One InkJet Printer Logo
209 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
