Question about Dynamode (R-ADSL-C4-W) Wireless Router
How do i get back to my pppoa connection set up?
I put the wrong username in...how do i change it ? please
  • budda666 Dec 11, 2007
    THANKS NKPRL...BUT DO I HAVE TO HAVE LAN WIRE PLUGGED IN OR RESET MY DYNAMODE R-DSL-C4W-EG ROUTER?
  • 54 Answers
Enter the routers' ip in IE and go to setup wizard
Posted on Dec 11, 2007
  • nik parelos
    nik parelos Dec 12, 2007
    FIRST PLUG LAN AND SETUP, IF YOU FAIL DO A RESET
A few weeks ago, one of my daughters friends changed my routers username and password, can you help me to find out how they managed to do this please many thanks mrs t holder
If you don't know the IP address of the router, you can open Windows Explorer, click 'Network', and then double-click your router. You'll be redirected to a webpage where you must put in a username and password. If THIS is the username/password she changed, the only way you can change it back without knowing what she changed it to is by resetting the router.This is usually done by pressing a small button near the back. If she changed the password that other computers use to CONNECT to the router (i.e. wireless), then you'll put in your username and password- the default is 'admin' and 'admin', unless you changed it- and from there you can enter the wireless settings to change the password back.
Aug 03, 2011 | Computers & Internet
No internet on TEW-672 GR (TrendNet) Router after i resettted it
once you have reset the router back to factory settings(using the pinhole at the back of the router and not just restart), you have to re-enter or re-configure your router for the internet connection depending upon your Internet Service Provider.Please contact your Internet Service Provider for the settings, use the CD that came with the router and re-enter the settings, once done, just turn off the router and turn it again. The internet will work.
The settings should be
  1. The connection type - PPPoe or PPPoA (ATM)
  2. Log in details for your ISP (username and password)
    These are the two main settings, apart from these, some more settings could be provided by your internet service provider. if they do not provide it, reply with your country, the name of your Internet Service Provider(like AT&T or Verizon etc)
May 28, 2011 | Trendware TEW-672GR Wireless Router
Belkin FSD7632-4 v8 wireless router will not connect to my ISP
It should be ok aslong as it is in sync. Can you tell me what router settings your using for talktalk? It should be PPPoA, Vc Mux, Mtu of 1432, Idle of 0. Ip assigned by isp is yes. Also make sure your username and password is correct.The username is going to be
yourphonenumber@talktalk.net and password is as provided by talktalk. IF your getting stable sync on the belkin the distance and noise levels shouldnt be causing an issue.
Apr 16, 2010 | Belkin (F5D7230-4) Router (587009)
DG834Gv3
RECONFIGURE THE ROUTER:
1. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.0.1 in address bar.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6lick on Setup Wizard and then select country and language then "Yes" and Click "Next" on the detection window.
7 It should give you a pppoa or pppoe detected"(type the Username & Password of your dsl account infomation which you got from isp)
8 Click Apply.
9 Open up another browser window and try to access internet.
regards
prakash
Jan 23, 2010 | NetGear DG834G Router
I'm having trouble with my DLINK dir-615 router. I can get a connection to the router through a wired connection and I also can connect to the router via wireless. I CANNOT get access to the internet...
I believe you have an IP Address conflict or the router needs to be configured for PPPoE. Here's how:
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Oct 22, 2009 | Computers & Internet
I downloaded latest security software from apple. now my wireless linsys g wrt54g won't work. I can connect directly to dsl, but can't make any connections with the router. I reset the router since it...
Step 1
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default password is `admin' (optional) and username is blank (nothing).
Step 3
Step 4
Step 5
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
How do i configure my dlink 302g modem to my new ISP's settings?
Hi Nitangel
Before proceeding with modem installation you need to gather your connection details from your Internet Provider. You will need to know or find out the following information about your new ADSL connection from your Internet Service Provider:
Connection Type:
PPPoE
PPPoA
Bridge RFC1483
Default IP address: 10.1.1.1 (USB 10.1.1.2)
Username: admin
Password: admin
· Username / password (PPP connections only)
· IP address / Subnet Mask / Default Gateway (Bridge connections only)
· DNS IP Addresses (optional)
To set up, log into the modem using your WEB browser: type http://10.1.1.1 in the address bar and press Enter.
Enter username 'admin' and
password 'admin' (default setting).
Go to Quick Configuration page.
Set Refresh Rate to "No Refresh".
If it is a PPPoE or PPPoA CONNECTION:
Select Operation Mode: PPP.
In the Connection Type drop-down menu select PPPoE or PPPoA profile.
Enter username and your password.
Select CHAP under Authentication Type (check with your ISP if not sure).
If it is a BRIDGED RFC1483 CONNECTION:
Select Operation Mode: Bridge. If you do not see "Bridge" options please update your modem's firmware at http://www.dlink.com.au/tech/
Select LLC or VC Mux as suggested by your provider.
Make sure your VPI/VCI is set according to your ISP requirements:
Click on "Save & Reboot" to save settings.
Then give modem a minute or two to reboot and reconnect. Restart your computer and you should be able to access the Internet.
You do not have to run any login client on your computer or router because your modem logs to your ISP automatically.
Hope this information helps if I can help further let me know.
Jun 17, 2008 | Computers & Internet
Draytek Vigor 110 modem
There is no default username or password to access the Vigor routers. Reset the router to clear any previous settings from its memory. Default IP Address is http://192.168.1.1 Manuals and firmware is available from the device maker.
May 17, 2008 | Draytek Computers & Internet
Siemens se 587 router
HI,
You can try manuall setup of da router.
The Default gateway for Siemens Gigaset SE587 is 192.168.1.1. Open Internet Explorer and put the def gateway in the browser.
The default username and password for siemns router is admin.
Click on Setup Tab than Basic Setup on left hand side. Update the details as folloing-
Use – Tiscali data PPPoA Interface
PVC Selection – Tiscali data PPPoA
Authentication – Auto
User Name - Tiscali u/n
Password - Tiscali password
PPPoA Connection Mode- Always On
NAT - ON
And click on save settings. To confirm if the customer is connected, check the status of Online light – which should be green
. Alternatively click on status (On top) to check internet status to confirm connection.
Setting Up Wireless connection – Click on da wireless tab on the top.
Ensure that the Auto channel is disabled and the wireless channel is 11, wireless n/w is Enabled and mode is Mixed.
To secure the wireless connection – Click on Wireless Security option on left hand side
If you want the Security mode as WPA than select the wireless security mode, as WPA and enter WPA Shared key which would be on the base of the router. Again click on save settings.
Try connecting to the wireless network again and I m sure it should work..... lemme know if it does.
Cheers
SHADAB
Mar 26, 2008 | Siemens SpeedStream 2624 Router...
Cannot connect to McAfee web sites from Centurytel.net
you can't update but you can connect to the internet? try to check the settings configuration of your macAfee.
Mar 13, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Dynamode (R-ADSL-C4-W) Wireless Router Logo
135 people viewed this question
Top Dynamode Computers & Internet Experts
Prashant M
Prashant M
gharibeh
Level 1 Expert
Are you a Dynamode Computer and Internet Expert? Answer questions, earn points and help others
