Question about Canon imageCLASS D880 All-In-One Laser Printer
Canon Imageclass d860 ADF feeder doesn't pull document through the feeder after a jam. When I clean the ADF roller, the roller doesn't turn 1/3 as the manual suggests it should. I can't find a service manual/info to figure out if there is a part that needs to be replaced.
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
  1. Press <Stop/Reset>.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
The hopper on top keeps jamming on D860!
If you are having jams in the Document Feeder, you should change the common rollers first.
Change these ones: FC5-0009 and FM2-0015
They're easy
Whit
Item, Inc
Oct 21, 2010 | Canon imageCLASS D860 All-In-One Laser...
What to do window says check document open ADF?
That means: open adf cover ( auto original feeder ) and remove jamed paper.
Probably adf needs some maintenance, clean rollers.
Jul 05, 2010 | Canon imageCLASS D880 All-In-One Laser...
Roller marks on copies. I ran the cleaning menu and it asks me to open the ADF to clean the rollers.. How do you do that and where is it.
The adf is the automatic document feeder and its located on top of the machine. use a clothe with 409, simple green or water and look in where you put your copies to be copied. You will see 2 grey rollers. wipe them off. NO alcohol Also are the marks on the docs you are running through the adf or comming out of the copier. Steven 818-888-0006
Apr 26, 2010 | Canon imageCLASS D860 All-In-One Laser...
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
Line on ADF feeder
Clean the narrow piece of glass inside the machine next to the large glass.
Oct 21, 2008 | Canon imageCLASS D860 All-In-One Laser...
Canon d660 imageclass copier
Hello himsmyboy!
Sikna says
The ADF separation pad is the cause. To remove it lift the cover fully up then use a knife to get under the black tape tab at the top right of the large white foam pad. Pull the tape and the white foam pad loose but not completely - leave the bottom attached. Now you can see the ADF separation pad from below. Use a small screwdriver or spring hook to remove the spring and you will be able to wiggle the ADF separation pad out. First take a good look at how it fits in so you can put it back! The problem is caused by the small black foam pad under the white rubbery tape on the ADF pad assembly. I carefully removed the tape from the back edge to expose the compressed black foam pad. I then cut a matching size of 1/16" foam I had in my shop which was actually HP 98A doctor blade seal foam and just stuck it on top of the old compressed foam. (other similar foam should also work) Then I replaced the white rubbery tape and rubbed the edge down well. I then reinstalled the restored ADF pad and the spring which holds it. Last I just pressed the large white foam pad back into position - being sure to pull it with a slight tension as I pressed into place. This fixed the ADF feed and it worked like new again...
Sikna out...
Jan 15, 2008 | Ricoh Aficio SP-C210SF Printer
Canon imageCLASS D880 All-In-One Laser Printer Logo
612 people viewed this question
old marine
old marine
