Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Toyo stove laser L-73 k-1 heater that smells after use.
I have a toyo stove laser L-73 k-1 heater that smells of kerosene after running inconsistently. All of the gaskets have been replaced. The unit has been serviced and there are no leaks in the fuel line. what do I do?
Buffalo12980
  • 625 Answers
SOURCE: laser 73
my guess is that your stove is almost like a monitor. the kerosene goes from your supply to the heater sump. there's a filter inside the sump. two screws will remove the plate where the filter is. the button you push on the side opens the float chamber valve and the kero just trickles in. up top is a solenoid operated pump that pulses when its working.
Posted on Nov 04, 2007
Buffalo12980
  • 625 Answers
SOURCE: Toyostove laser 73 heater with a EE 2 error
replace the flame rod. or it could be the computer board for the flame rod. flame rod detects the presence of a flame.
Posted on Dec 02, 2007
Pnutgllry
  • 57 Answers
SOURCE: toyo laser 73 stove
Try trouble shooting at this website....
http://www.rural-energy.com/publications/catalog/category/101
Posted on Oct 19, 2008
toyotech
  • 8 Answers
SOURCE: Toyo stove laser 30
EE22 means that your Toyo failed to ignite 3 times in a row. You need to unplug it for 30 minutes to reset the circuit board. Then plug it back in, push the red reset button on the right hand side in the little hole towards the back and push the Power button. Your Toyo should ignite after that barring some other problem caused by running out of fuel.
I am assuming that you ran out of fuel which caused the EE2 error code originally. Sometimes, when you run out of fuel you can get water, ice, debris in the fuel line causing an obstruction or limited fuel flow. You may also get an air lock. You may need to crack the fuel line at the back of the Toyo where there is 3/4 nut and bleed the line. If you see no fuel or a small quantity of fuel then you will need to thaw and/or purge the fuel line in order to get fuel to your Toyo's fuel pump.There is also a screen in the sump which can get plugged with rust, debris from the bottom of the fuel tank so you may need to clean the screen in order to get fuel to the pump.
Posted on Nov 13, 2008
SOURCE: ventless gas heater smells like kerosene
It is posible that your heater is burning fumes from paint, varnish or stain and some times carpet cleaners or other household cleaners. I work for a utility company. We get called to homes for a lighter fluid/kerosene smell quit often. Most of the time it is from the fumes burning off on a standing pilot gas oven. The odor collects in the oven and is released in the customers face when they open the oven door. This will happen with any open flame appliance when exposed to these fumes.
Posted on Nov 04, 2009
Is it allright to burn part deisel with kerosine in a Toyo laser ignited heating stove?
Only if you want to stink up the house (more than just what the kerosene does) and don't mind dealing with a little soot on the walls and ceiling.
I wouldn't. But the choice is yours to make.
hope this helped you in some way. Please let me know. Thanks.
Jun 09, 2011 | Rinnai Toyostove Direct Vent Heater:...
Laser 72
Your manufacturer, Toyotomiusa, recommends that you tighten all the joints on the fuel line. Your owner's manual CLICK HERE contains detailed drawings showing the location of all parts, including the fuel injector. Your unit will need to be serviced by a qualified technician if you have tightened the connectors and still smell kerosene or find wet spots under your heater. It should not leak or smell of kerosene. If you're smelling kerosene, you should not operate the unit, because the leak may cause a fire.
Jan 15, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyo laser 73 error code EE8. What does that mean?
All error codes are explained on the lower left side of the heater. The EE8 message is for the combustion blower motor. If your stove has been unused for the summer you may get away with just spinning the blower wheel by hand to free it up. If this does not work you are in for a new motor or assembly. Either way you need to clean the blower and heat exchanger.
Tom
Aug 23, 2010 | Rinnai Toyostove Direct Vent Heater:...
Ok we were given a laser 73 and we have checked and there is kerosene reaching the heater but it wont lite what could i do
Check to see if Igniter is working (Dont touch)
just feel close to it, should be warm and you should see a glow inside the peep window.
Ask about service history It may be time to get it fully serviced
Good luck
call me if you need more help
Total Toyo
(907) 488-9179
Dec 07, 2009 | Rinnai Toyostove Direct Vent Heater:...
I need to get replacement parts for my laser 73 stove and no one around seems to carry them? Any ideas?
Any dealer that sells new Toyo stoves should be able to help you.
I don't think the rules of this site will allow me to post the web address of the dealer I use; but typing "Toyotomi heater service" into Google pulled up quite a few dealers.
Hope this helps!
_Helping Hands Services_
- Fairbanks, Alaska -
Oct 27, 2009 | Rinnai Toyostove Direct Vent Heater:...
I was told my Toyostove Laser 72 stove needs to be cleaned. Can i do this myself and what do I do.
I would recomend having a qualified technican service your Toyo.
It IS possible to clean it yourself, but you will want to do it during a time that you aren't needing the heater to keep the space warm.
Certain parts can be hard to tell if they are working as they should if you aren't familar with what you're looking at.
With proper service, your Toyo will operate efficently, and likely last for a long time.
Oct 05, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyostove L-73
I have used #2 in the summer. I have been told the difference between 1 and 2 is 1 has an additive so it won't free. I would use oil meant to be used as heating oil because it should be lower in sulfer.
Nov 18, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyo 73 don't work
Take a look at this...
http://www.rural-energy.com/publications/catalog/document/338
This site says there is a problem with the blower motor assembly.
Apr 28, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
456 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
