Question about Honda Garden
13 HP honda shuts down after 30 seconds, already tried disconnecting oil pressure switch
  • 174 Answers
1) check your pressure washer nozzle isn't partially plugged
2) the carburetor may need cleaning
Posted on Sep 17, 2009
Mow for 30-60 min.mower shuts down. Sometimes you can mow all day.start goin up hills mower will shut down,about the second or 3rd trip.what's the problem?
Don't know what kind if engine you have but many have low oil shut down float switches inside the engine..when operating on hills or side if hills too long the oil will flow to the low side and the low oil switch will pick it up as low oil and shut it down..look for a small wire attached to the crankcase it most likely is that low oil switch..the next time this happens try disconnecting it and tape the end if the wire..try starting and run on the hill..it should not shut Down..just remember it is a safety switch to protect the engine from damage from low oil operation.try running the hills where the oil runs to the wire side of the engine..won't trick the low oil alert...Good luck..
Aug 08, 2015 | Garden
13 HP Engine GX390 OHV Horizontal Shaft. runs perfectly fine/pressure fine for 2 to 3 minutes then shuts off. Have to restart over and over and over. Checked oil, no smoke, took air filter off, cleaned...
Check that the fuel tank is not creating a vacuum. this will starve the engine. After it shuts down the vacuum dissipates and lets the fuel run into the carb again.
Sep 10, 2013 | 13 HP Engine GX390 OHV Horizontal Shaft
Won't Stay On
If it's brand new, the first thing I'd check is the oil level in the Honda motor. Most pressure washers are tested then the oil is drained out for shipment. Honda motors have an oil sensor in them that will shut the motor off if the oil level is low. When the motor is off, all the oil is in the bottom of the crankcase and the sensor 'thinks' all's OK. When you start it up and the oil is getting splashed around it will get low enough for the sensor to shut the motor down. Also make sure the gas is turned on at the carburator.
Sep 04, 2012 | Homelite Pressure Washer. Honda 2700 psi...
1997 DeVille Concourse; After about 30 minutes, oil pressure idiot light starts blinking nd worsens to the point where the computer says engine oil pressure is low and to shut engine off.
Given that this car is 13 years old already, try replacing the oil filter(AC Delco) and use a higher grade oil than what you are using now. If this does not help, it is going to need to be tested with a "wet gauge" for proper oil pressure to make sure there is not a mechanical issue such as a worn oil pump.
May 22, 2010 | 1997 Cadillac DeVille
My 40g shuts off after running perfect for a feww minutes
It is very likely you are having a problem with the low oil pressure switch or the high temperature switch. Both of these are connected to the No.85 wire which in turn goes back to the control board. If the temperature exceeds the predetermined level (apprx 305 degrees F) the high temperature switch will then ground wire 85 causing the unit to shut down. Same thing with the oil pressure switch, if the oil pressure switch goes below 10 psi the low oil pressure switch will ground wire 85 causing the unit to shut down. To determine which is causing the problem disconnect first the low oil pressure switch (Located by the oil filter) and start unit if it contunues to run after 10 seconds and does not shut down then the oil pressure is the problem. Then you must use a mechanical pressure gauge connected where the low oil pressure switch is to determine if you actually have less than 10 psi of oil or if the low oil pressure switch is just bad. Try the same thing with the high temperature switch also located close to the oil filter if you disconnect it and it continues to run more than 10 seconds then you have and engine that might be overheating. Anything that gets caught in the air intake on the generator itself ill cause this unit to overheat, I've seen it **** garbage in through the air intake and cause the unit to overheat because of poor air flow. If their are no restrictions and you have good air flow than chances are you have a bad high temperature sensor.
Hope this helps, please let me know.
Dec 01, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
What do I use for oil in motor?
I always use synthetic oil in my small engines, and recommend it. Use 5w-30, 5w-20, or 10w-30
Nov 03, 2009 | Mi T M 13 Hp, Honda Ohv, Compressor, 3500...
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
When shutting down the compressor, oil comes out intake filter
hi there,
well,if your air compressor was shut off this due to pressure switch w/c auto switch off your compressor,the pressure switch acquired already the cut off pressure.if the pressure goes down the cut in set up reached it will start your compressor
to run.
regarding oil spillage when shutting down check the oil level on the sight glass of crankcase
a red line indicate oil should not exceed on that level line,if the oil exceed try to drain oil.,on the side bottom of engine there is a drain plug.until on limit level .,besure that machine is shut off/breaker is off.have a nice day don't forget to rate me,thank's
Apr 28, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Garden Logo
116 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
