Question about Cell Phones
Screen is hazy and full of lines,nothing readable
On an Acer Aspire 1640z I get blue screen and lines. lines move with track pad movement. nothing readable. replaced lcd cable and inverter. thinking either lcd or motherboard
Hook it up to an external monitor. If the display is fine on the external then your gpu on the motherboard is fine and the LCD is bad. No external display means bad board. Both cost roughly the same but an LCD is much easier to replace than the board.
Apr 07, 2011 | Acer ASPIRE 1640Z COMPATIBLE LAPTOP LCD...
My sony rear projection kdfe50 has a blue hazy line at the bottom of the screen
If that blue hazy line is there in all inputs and no signal, you have a defective light engine. Contact Sony Customer Support because they extended the light engine warranty on some models.
Dec 26, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Philips big screen hazy/color problems easy fix?
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
  • Halos around objects
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 28, 2009 | Televison & Video
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
48" rear projection hazy/bad picture
most fluid changes would fix that. I recommend doing all three but that's just me. Also make sure the crt's are full as this would cause the set to be out of focus. also make sure you don't move the yokes too much because you can knock the convergence out pretty bad and also have a blurred pix
Jan 09, 2009 | Televison & Video
Laptop screen damaged?
Nothing is ever broken beyond repair, but most of the time the cost of repair actually exceeds what you can purchase a new one for. And with 19" LCDs selling for around $139, you get a bigger screen and less money than it would cost to actually replace the screen on that monitor.
Thanks and please take a moment to rate as fixya.
Nov 07, 2008 | Dell E173FP 17" LCD Monitor
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Same problem
heat the screen gently with a hair drier
Sep 08, 2008 | Samsung Digimax S500 Digital Camera
Cell Phones Logo
81 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
