Question about Dryers
Kelvinator Dryer - Taking Front and Top off
I am trying to find the manual for a Kelvinator Dryer DGT400KW2. Because I can not figure out how to take the top and front off. I need to check the gas valves.
Thank you.
  • Dryers Master
  • 8,220 Answers
Posted on Sep 11, 2009
HOW TO FIT A DRUM BELT ON A TUMBLE DRYER KELVINATOR
Normally you loosen the bolts to the motor after fitting the belt around the drum. DON'T try to streach the belt to fit over the motor pullery.
Dec 19, 2011 | Dryers
Need belt diagram for GE dryer, Model No. DBSR453GB3WW
try this site it has free manuals for dryer repair, you should be able to find all you need there....
Nov 11, 2011 | Dryers
I think a mouse got in the back of my dryer. And may have knocked it off track the drum doesn't turn easily and won't go when we try to turn it on. We are trying to figure out how to take the back...
The back does not come off. You work from the front.
Take the top off first then the front.
Service Manual
Note: I have over 30 LG dryer manuals and most are identical
Jun 05, 2011 | LG Dryers
Need to remove front panel to get at belt. The drum isn't turning. Cant figure out how to do this! help
I think you need to take the top off, then the front panel will be easily seen, and you can start taking off the screws.
Jun 21, 2010 | Maytag MED5600TQ Electric Dryer
I'M TRYING TO REPLACE A SQUEEKY PULLEY
Unplug the dryer.
Remove the top. Then the front panel. Then the front support. Then the belt. Then the drum.
Probably not a squeaky pulley.
Probably a bad drum bearing.
Mar 11, 2009 | GE DBXR453EV Dryer
Dryer Baffle Coming Loose
See if there are 2 screws located at the bottom front of dryer,unscrew anft panel up untilthe clips that are at the top disengage, disconnect door switch and any other connections , taking note of the connections.
W
Jan 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I can't figure out how to get into my front loading LG dryer.
Heres a link to the schematic. Youll have to start by taking the top off. There are 3 screws on the rear top that hold it on. After you take them off, you should be able to slide the top off by pushing it back. In the diagram youll see the screws in the top front that hold the front panel on. Also when you open the front door there are a couple screws that need to come off the face. From there the front panel should pull off. Hope that helps. Dave www.washermd.com
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f50030341-00002.png
Dec 16, 2008 | LG DLG7188 Gas Dryer
Need to get into the dryer to fix it.
Hello barbmaresca,
Here is a link to your dryer with exploded views and parts lists for you to look at but in general, you should be able to remove the front panel by taking out the lint filter and removing the screws that hold the filter housing to the top lid, then by prying up the front of the lid from the frame. You may need to use a pry bar or large screwdriver to pop the lid up from the clips and it should remain engaged by the back hinge plates. Be sure to disconect power before performing any service.. Here is that link
http://www.pcappliancerepair.com/model-display.php
Hope this helps you..
Regards,
Rick
Nov 23, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
210 people viewed this question
Top Dryers Experts
