Question about Pioneer AVIC-D3 Car DVD Player
The disc looks like it turned from a silver color to blotches of gold and the screen says error reading. where can i get a replacement disc ??
KF-50WE610 blotch of color on screen
Either dust/dirt inside (unlikely but possible) or a damaged optical light engine--Google the model number with "problems" etc.
Apr 17, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Both the the left and right have large color blobs, more intence at times, shows more on blk/white
There is a degaussing resistor that activates when tv is first turned on and purifies the screen so there is no color contamination, sometimes it will become defective or develope bad connections on the circuit board. The part looks like a box "black/green" and is located near the power cord. If it has stopped working it would explain the color blotches. To fix it! the part needs to be replaced or resolded back on the board and a degaussing coil used to give it the once over, tv tech carries one just for that purpose. The other possibility is if speakers are to close to the viewing screen the magnet will leave blotches and must be degaussed to correct it.
Feb 07, 2011 | Philips Televison & Video
Why won't my playstation 2 read colored discs? It reads silver discs fine, but red, black, blue, etc., get disc read error.
That is a very odd problem. There are a couple reasons this could happen. The first depends on the age of your console. If this is one of the older systems, (one of the first one's sold), then it could be that those disks are incompatible with your firmware. Otherwise, it would sound like the eye of your disk reader is malfunctioning, and not reading through the colored plastics correctly.
Oct 04, 2010 | Sony PlayStation 2 (PS2) Console
HI, I have a NEC monitor 1760nx, dark blotches on the screen
Listen, for what it is going to cost you to fix the unit, you are better off replacing it and having a new warranty to boot. Simply not cost effective to repair given the cost of a new monitor these days.
Mar 12, 2017 | NEC 1760NX-1 (White) 17 in. Flat Panel LCD...
Something to make soft solder blend in more to gold color jewelry
Was looking for a patina - used in stained glass - this is what others suggest...
"I use gold leaf paint at my solder points in a stained glass piece to make it look like brass. Have repaired many pieces and used the gold leaf paint and works very well. I think the paint works better than the gold pen."
Gold'ish color at least - hope this helps... Dan
Dec 09, 2009 | Welding Tools
Describe your Nintendo Pokemon silver When i save on my silver version, turn off the game, then turn it back on there is no continue, just new game, but very very very very rarly it let me continue but its...
calm down the save battrey went dead mine contenues but it didnt then open the case,the battery in the corner is it if it hasent exploded carefully work it out and remove it and replace it
Aug 10, 2009 | Nintendo Pokemon Gold
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Read disc error tweaking dont help
common problem with all PS systems, I have had the same problem with my PS1, PS2 and the PS3 - opted me to move away from PS.
Unfortunately I don't have a solution for you other that to replace the lens, each one of my machines I had to replace.
Even feedback from sony suggested lens replacement.
Good Luck.
Apr 14, 2009 | Computers & Internet
Pioneer AVIC-D3 Car DVD Player Logo
37 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
