Question about Whirlpool Dryers
My Whirlpool Dryer has the light which turns on when the door opens, but there is no power to the display and it won't turn on. Model # GEW9250PL0 SER# MS2315644
  • 1 more comment
  • connieklug Sep 11, 2009
    OK, I've taken the whole thing apart already. You lacked telling me what to do after I get it all apart.
    Do I need to buy a new panel?
    I have taken my dryer completely apart-back panel, top panel and checked all of the wiring. Everything looks good. The first expert told me to take it apart and unplug everything on the panel. Then no solutions after that. Does he want me to replace the panel? Where do I order one?
    I don't know. I'll have to switch out the control panel and see if that fixes the problem to be able to answer if the solution helped or not. But I do appreciate the advice.
  • 6,784 Answers
HI. The first check point will be to inspect the door switch for faults. You have stated that the light illuminates when the door is ajar. This will rule out any door switch issue,and point to an electronic control assembly failure at this time. I recommend the replacement of this failed control assembly(board) asap. It has failed. The logic sector on this failed board is damaged. The user interface receives its power, via electronic control assembly(board). If the user interface(display), has no power, this will confirm my diagnosis.
Part Number is 8546219
Posted on Sep 11, 2009
  • 1,031 Answers
The control board is usually the problem The procedure is simple, after unplugging the dryer, it just takes 7 screws to remove and about 6 things to unplug on the board. I recommend labeling the connectors or take a photo before you unplug things for reference.
It took me about 30 minutes to do this fix.
Whirlpool cabrio gas dryer model WGD6200SW1,
I would hold door button in with door open does it heat if so I would look at belt that turns drum if broke or just came off lower drive pully.hope this helps
Feb 12, 2015 | Whirlpool Dryers
Frigidaire electeic dryer won't turn on.
Have you checked the door switch to make sure it is closed when the door is closed?
Jan 21, 2013 | Frigidaire Dryers
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
Whirlpool model LER8648LW0 - the dryer will not stop when door is opened and the interior light does not light. I have changed the bulb on the light but it still does not work. I suspect the problems are...
I suspect the problem with your dryer is the door switch as opposed to the timer...its the responsibility of the door switch to stop the dryer when the door is opened as well as turning on the light too when the door is opened.
The part number for the door switch is 3406107 it could be purchased at your local appliance parts store or online at;
apdepot.com
repairclinic.com
searspartsdirect.com
apwagner.com
partselect.com
This youtube video will show ya how to replace the door switch http://www.youtube.com/watch?v=gWQhuQXa6d0
GENE
Sep 12, 2011 | Whirlpool LER8648L Electric Dryer
The dryer won't turn on when plugged in. However, when I open the door, the drum light turns on.
I have the same dryer and the same problem...I have power to the unit but it wont turn on....the light in the door is on....there is a small cllick to the top left when I try and start it..thats it..!!...did you get a solution yet?..thanks..mike
May 15, 2011 | LG DLGX7188 Gas Dryer
I have a whirlpool model number GEQ9800PW1, the serial number is MS2024548. I just noticed tonight that when I opened the door the light didn't come on, I thought well I can live with that, but when I...
door switch: http://www.partselect.com/dryer+replace-door-switch+repair.htm
to open dryer: http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
can buy at a appliance repair/service shop, online or eBay. Good Luck Tim
Nov 29, 2010 | Whirlpool Dryers
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
Dryers Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
