Question about Xerox WorkCentre Pro 555 Plain Paper Laser Fax
Right side of Print Out is faded. Cleaned, and Cleaned. Doesn't say to change drum/ink. What else can we try?
    Brigadier General:
  • 4,044 Answers
You can try shaking the toner cartridge to even out the toner but most likely either need a new toner cartridge or the drum is not sitting evenly as it should.
Posted on Sep 11, 2009
When I print on my HP Color LaserJet 2600n Printer the far right(1 inch) of the page is faded and is unable to be read. I have replaced the ink cartridge but it doesn't help
Have you cleaned the print heads? There should be a program that came on the drivers disk that includes a "service" tab where you can align and/or clean the print heads automatically. If they are particularly dirty and have never been cleaned, you may have to run it through two cycles to get it right.
Oct 05, 2011 | HP Color LaserJet 2600n Printer
Hi, I have had my CLX-2160 printer for 3 years now and its started to print with a fade on the left side only and have just under half black ink left. Is it worth changing the black toner cartridge or does...
Hello.
There are two reasons the fade happens. Running out of toner and the drum not responding correctly. The Drum is the unit that transfers the toner to the paper. if it gets damaged or dirty inconsistent print is usually the result. Try taking the toner out, shaking it and replacing it to see if it affects the print quality. if it does not price a replacement drum and toner, compare it to the price of a new printer and this will answer the second part of your question!!!
I hope this helps Regards GM
May 27, 2011 | Samsung CLX-2160N All-In-One Printer
The print on the right side of the page is faded.
Could be the fuser, or the drum is not getting the charge on that side.
Dec 08, 2009 | Konica Minolta PagePro 1350W Laser Printer
Faint area down left side of page
When you say "Cleaned the lens" I presume you mean the four LED print heads. Use a spirit to clean them with if the toner dust is hard to remove. I usually just use a finger and wipe the entire length. Make sure there is no foreign item laying on the drum top where the black plastic film is as the led head may not seat properly on it. Clean all the silver high voltage springs down the left side of the printer. They make contact with the drums. If you still have a problem then try printing solid colour blocks ie Yellow, Magenta ,Cyan and Black . This will identify which colour is giving the problem . Change that drum and all should be well.
Jul 26, 2017 | OKI C3400n Laser Printer
Poor, faded print quality on left and right sides of paper
Have you check the teflon at the heater? have you clean the reflector of laser? Try that.
May 30, 2009 | HP LaserJet 8550 Printer
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
Black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
Printer won't print
My printer will not print black ink. The color ink is very light. I replaced a new color cartlidge, cleaned the printheads and tried to callibrate, but the printer could not identify the callibration page from my scanner. Can you help me resolve my problem?
Thanks,
Carol
May 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Xerox WorkCentre Pro 555 Plain Paper Laser Fax Logo
193 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
