Question about Snom 320 IP Phone
The display on my Snom 320 doesn't work? The phone's lights also don't work, but the buttons and functions do work. Is the phone broken? This is a brand new phone, just out of the box.
  • 339 Answers
Do you have the power brick hooked up to it? If so, try another one if possible as it could be the defective component.
If you're using POE to power it, make sure you have pluggd into a POE port for sure.
If you still have problems after this, then you need to return it for replacement unit.
Posted on Oct 01, 2009
How do I get the phone to ring when a guest calls. We can make out calls but when people ring in they get a message only to leave a message?
Make sure the DND (Do Not Disturb) feature is not activated. If it is, the icon next to your name in the display changes from a phone to a minus sign and your phone won't ring. If that doesn't fix it, please provide more information - what type of PBX or hosted PBX is the phone connecting to.
Feb 13, 2015 | Snom 320 - VoIP Phone
Default snom 360
Maybe you have to install a "recovery" OS on the phone. You get it from the snom-website, but you have to use a TFTP-server on your PC. When you boot the phone, the display says something like "TFTP bootoing....press any key". Then you enter the IP-adrwess of your TFTP-server and some other information and the OS will be loaded to the phone. If you get this working, everything is set to factory default and you can update the OS to the latest version. All passwords are set to default-values (or empty - I do not remember now)
This sounds more complicated than it is :-)
Apr 26, 2014 | Snom Computers & Internet
I have a snom 320 dialling out takes long time for connection
I guess this is a SIP phone , try dialling the number then add # at the end, a SIP phone does not know when you have finished dialling unlike a landline so # complets the dialling for you
Jul 12, 2012 | Snom 320 IP Phone
How do i name my phone
This is usually the switching unit's function.
Oloff Crous
Jul 07, 2012 | Snom 300 IP Phone
I have a snom 370 voip phone with the plantronics cs70 headset but there's a bad echo on the callers end so i got the snom wireless headset adapter but i don't know how to connect it. i also have...
We've never dealt with snom wireless adapter but the CS70 and HL10 lifter is a popular set for your phone. there are a couple of things you can try to cut down on the echo.
1. Make sure CS70 is proper distance from phone, minimum of 6" (12" from a PC)
2. Make sure round compatibility dial (located on left side of base) is set correctly. Most phones work on setting #1 (never between numbers)
3. Echoing is usually caused by an improper mix of incoming and outgoing volume. With a friend listening in you can make broad and minor adjustments for both (incoming: back of base (1-4) and +/- on headset; outgoing: bottom of base (a-d) and +/- arrows on back of base).
Following these steps should help you out.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics CS70 Wireless Headset
My snom 300 phone displays NR help please
try resetting the vlan settings if that doesnt work ensure that the default gateway and dns settings are correct.
Dec 08, 2010 | Snom 300 IP Phone
My snom 300 phone rebooted but displays NR
Go to vlan settings, then pick reset . The phone would restart itself and that should do the trick.
Jun 09, 2009 | Snom 300 IP Phone
My snom 300 is dialling letters instead of numbers how do I fix
Pick up the handset and press down on the direction button until the display reads "123" instead of "ABC" or "abc"
Oloff
Nov 25, 2008 | Snom 300 IP Phone
Snom 300
this is not a solution - we have the same problem too.
have about 70 snoms here and sometimes the display shows only black boxes. a reboot helps then mostly for a while.
telephones are connected by poe or voltage adapter.
never had over voltage and i can't remember on power outages.
Sep 08, 2008 | Snom 300 IP Phone
How to unlock phone
Press and hold down the * button until lock is removed.
Mar 27, 2008 | Snom 320 IP Phone
Open Questions:
Cannot dial out on an SNOM320 SIP Phone I have forwarded the ip address of the phone through the router as a DMZ. I can call out using the software on my computer without any issues but not using the phone. Here is the log file information: System Information: Phone Type: snom320-SIP MAC-Address: 0004132C7E7D IP-Address: 192.168.1.101 Firmware-Version: snom320-SIP 8.7.3.19 Firmware-URL: http://provisioning.snom.com:80/download/fw/snom320-8.7.3.19-SIP-f.bin Production Information: Mac:0004132C7E7D;Version:Standard;Hardware:snom320 (H: R2A);Date:25/06/08;Copyright(C) snom technology AG Uptime: 0 days, 0 hours, 1 minutes LCS: 0 days, 0 hours, 0 minutes (0) Memfree: 1580 K CPU: 0.03 0.01 0.00 1/10 10 Bootloader-Version: 1.1.3-u Expansion Module: (0) SIP Identity Status: Identity 1 Status: 12262898960@voip.freephoneline.ca: OK Identity 2 Status: Identity 3 Status: Identity 4 Status: Identity 5 Status: Identity 6 Status: Identity 7 Status: Identity 8 Status: Identity 9 Status: Identity 10 Status: Identity 11 Status: Identity 12 Status: Ethernet Status: Net Port: Connection Type: 100 Mbit Full Duplex Status: connected PC Port: Connection Type: Status: not connected Call being received by Snom320: 9/2/2013 11:28:08 [NOTICE] PHN: RTP: set_destination adr=208.85.216.38:11468 Call being placed by Snom320: 9/2/2013 11:28:08 [NOTICE] PHN: RTP: set_destination adr=208.85.216.38:11468 9/2/2013 11:28:36 [NOTICE] PHN: TPL: Socket 31 idle/connect timeout 9/2/2013 11:29:01 [NOTICE] PHN: SDP: Skipped Codec G723 is not supported for 20 ms packets 9/2/2013 11:29:02 [WARN ] PHN: SIP: process_registrar_packet: 401 needs 128 bit nonce 9/2/2013 11:29:02 [NOTICE] PHN: SIP: process auth:Match challenge for user=12262898960, realm=voip.freephoneline.ca 9/2/2013 11:29:22 [NOTICE] PHN: TPL: Socket 32 idle/connect timeout 9/2/2013 11:29:34 [ERROR ] PHN: SIP: transaction_timeout udp: 1000018 (32000) 9/2/2013 11:29:34 [ERROR ] PHN: SIP: transport error: 1000018 -> udp:208.65.240.170:5060 9/2/2013 11:29:34 [NOTICE] PHN: SIP: Add dirty host: udp:208.65.240.170:5060 (0 sec) 9/2/2013 11:29:34 [NOTICE] PHN: SIP: final transport error: 1000018 -> udp:208.65.240.170:5060 9/2/2013 11:29:35 [ERROR ] PHN: SIP: transport error 1000018: generating fake 599 9/2/2013 11:29:37 [NOTICE] PHN: Fetching URL: snom://mb_exit 9/2/2013 11:30:35 [NOTICE] LID: testNetworkPolicyIsSet This has been frustrating me for a long time and I would appreciate any suggestions. Thanks.
Feb 09, 2013 | Snom 320 IP Phone
Snom 320 IP Phone Logo
262 people viewed this question
Top Snom Computers & Internet Experts
David Payne
David Payne
Are you a Snom Computer and Internet Expert? Answer questions, earn points and help others
