Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Works for a few days and stops , unplug it for day and will work again for a few days
  • 60 Answers
Sounds like control or Thermostat call your autorized repair person near you and they can fix you up pretty quick most carry thermostats for you brand in their depot. Average repair to be done in an hour.
Cheers
Al
Posted on Sep 11, 2009
When i push the start button nothing comes on,if i unplug the machine and plu it back in the machine works fine for a while than stopes working
You need to offer more info for us to assist with possible fault.
When you say unplugging/re-plugging it allows it to work for a while, please explain - do you mean it works for a few minutes, it for a few hours or for a few washing cycles/days? Does it stop part way through a wash, or once started will it always finish a wash before failing again?
Dec 15, 2013 | LG Wm2688hnma Front Load Washer wm2688hnma
Hello, my frig gets real cold but one day compressor stopped frozen stuff started melting. unplug plugged in few hours later it works for a week off again cycle continues for a few weeks. I replaced the...
0ba250e7-c31b-40ec-b003-ff0da31d62e4.jpgThis could be caused by a couple of things. If the condenser fan is defective and stopping while you don't see the fan stop it will cause the compressor to overheat and stop. The other possibility is a defective=> 12784415 Main Control Board or JAZZ Board A defective relay on this board will cause the same symptoms, Sea Breeze
I am here if you have questions...JT
Sep 21, 2013 | Maytag Refrigerators
I bought the amp a few weeks ago and it worked perfectly for a couple of days and then for some reason the controlls just froze. the tap tempo light went out and the channel control light stayed the same...
Exercise your warranty IMMEDIATELY since you just bought it! If you bought this used, you LIKELY bought someone else's problem. The problem is likely in the digital effects area... probably a bad cable contact... but if under warranty DO NOT mess with it... return it for replacement or repair.
Sep 09, 2011 | Marshall Amplification Marshall MG30FX...
My garage door opener justg stops working. I have
TRY INSTALLING A SURGE PROTECTOR.
IF IT CONTINUES AFTER THAT YOU MAY HAVE A BAD CIRCUIT BOARD
May 14, 2010 | liftmaster Chamberlain Garage Door Opener...
While cooking on my GE electric oven today I spilled water over the stove top by accident, now the iginite pilot wont stop sparking, what can I do to fix it? other than unplugging the oven as a quick...
If it's just water, unplug it for a couple of days and turn the switch back and forth a few times during these couple of days. The water should evaporate and your cooktop should start working again.If this did not help - one of the burner switches (or assembly with all switches and wiring, depending on model) will need replacement
Apr 03, 2010 | GE JKS06BFBB Electric Single Oven
TRY GETTING A SURGE PROTECTOR. 990LM
THE OPENER HAS NO BUILT IN SURGEE PROTECTOR AND THE MAIN CIRCUIT BOARD IS SENSITIVE.
Mar 24, 2010 | liftmaster Chamberlain Garage Door Opener...
Emerson SmartSet Dual Alarm Clock Radio Won't Stop "Flickering"
Problem was solved. When clock was plugged in after a few more days, it finally stopped flickering and reported an incorrect time and day. Low battery was now blinking! Checked calendar and found all memory was lost. Purchased and installed a new battery and this time when clock was plugged in it correctly set itself! Fixed.
Sep 27, 2008 | Emerson Audio Players & Recorders
GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Aug 27, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
99 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
