Question about Air Tools & Compressors
Converting 3 phase compressor to single phase (100LTR tank . 2 H.P. Motor) Need a wiring diagram . Please
  • daniel  hendrickson
    daniel hendrickson May 11, 2010
    WHY????? did you move where there is NO 3phase service??? its going to cost you so much more to run this machine on single phase current,because of your increased motor size if you can find a motor that large(single-phase) if this is the case find a gasoline engine 18+H.P. it will be just as cheap to operate
    Problem Solver:
  • 6 Answers
Start w/ a single phase motor. Or maybe your question is just confuseing me.
Posted on Sep 12, 2009
I have a Ingersoll Rand Compressor model# 2545E10V 10 HP,3 phase and I would like to convert it to a signle phase. would this motor here be good to go with and what other items will be needed to complete...
It might. Mounting holes match? Shaft diameter and adapter match? Power supply sufficient for 5HP motor? It's a big motor! You might get a better answer from the ebay supplier.
Mar 05, 2015 | Ingersoll Rand Air Tools & Compressors
Wire 230 volt air compressor wiring diagrams
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Feb 11, 2014 | Air Tools & Compressors
I have an ingersol rand 2420n5 t30 and i want to convert it from single phase to 3 phase any help thanks
Hi robles212
To convert your T-30 to single phase you will have to do one of two things.
1. Change the motor to a single phase motor
2. Buy and install a "Phase Converter" to convert 3 phase to single phase
Please rate me
Bud
Oct 08, 2012 | Ingersoll Rand Type 30 Reciprocating Air...
Ajax 5hp air compressor wiring diagram Problems
If you're running 3 phase, swap 2 infeed wires. If you're running single phase, look in the wiring diagram in the motor head for the wires to move.
Jan 31, 2012 | Air Tools & Compressors
Have a 3 phase compressor model vr5-8 want to know if it can be converted to single phase 230 volt and how
A 3phase motor cannot be rewired to run on single phase power. You need a phase converter. A 3-phase motor will only run on 3-phase power, and a phase converter will convert single phase power to 3 phase. Just google phase converter. There are two basic types, electronic and rotary. The rotary type are more powerful and efficient, but lot's more expensive than the electronic ones. Your only other option is to replace the motor with a single phase motor. Good luck.
May 17, 2011 | Garden
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
I have a 3 phase electrical motor for my air compressor, How would i connect this from the air compressor pressure switch and towards the electrical source 120V? (for low volt)
If the electrical 120 volt source is single phase, the only way to run this motor is with a single phase to three phase converter. Best to sell the three phase motor and obtain a similar horsepower 120 volt single-phase capacitor-start motor (1750 RPM) for the compressor. You would also require a 3-phase pressure switch for use with the 3-phase motor. Hope this helps!
Nov 05, 2010 | Garden
Can I change model 754 machine from three phase to single phase by just replaceing the three phase motors with single phase motors?
no you cannot. The cost to replace the dasher motor and compressor would be extreme. In addition, you would need to convert the controls from 3 phase controls over to single phase controls.
Those machines are designed for 3 phase power. If you could get the same components in a single phase version, you would spend more money economically than its worth.
Take the money you would spend converting and purchase a single phase countertop unit. They are made.
Feb 11, 2010 | Taylor 632-27 Ice Cream Maker
Converting from three phase to single phase
Do you want to convert 3 phase to single phase?What voltage do you currently have (220v 3phase)?
May 07, 2009 | Kitchen Appliances - Others
Air Tools & Compressors Logo
424 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
