Question about Jensen Car Audio & Video
Cant figure out how to set anything on it, time, channels, band. Is there an online manual?
    President:
  • 1,126 Answers
Http://mobile.jensen.com/jensen/
Input your model number to download a user guide.
Posted on Sep 13, 2009
Why will my rca trflat not go past cannel 69
Hi there. Maybe your TV is not equipped for S channel reception.
Channel 73 falls into the S band; (21-69 is the normal UHF band.)
However in most cases, you must choose in wich band you scan your channels; (H, or S) I cannot imagine that this modern TV should not be equipped for S channels. Try manual channel search, where you'll probably find this possibility.
Oct 03, 2014 | Televison & Video
How to put together the drive shaft assembly on a Grob 4V - 36 vertical band saw
I suggest you to check the operators manual. If in case you don't have the manual, contact Grob's technical assistance or you can get a manual available online. I got old manuals from bandsawmanuals.com but they don't have available manual for 4v-36 . By the way, I like the solid build saws from Grob, what's your usual cutting workload? I have 7x12 band saw with a Haltbar band saw blade from sawblade.com ,I cut structural steel, channel, angle, tube, plate, pipe, round bar,
Dec 27, 2013 | Grob 4V-36 - 36" Throat Band Saw
Kenwood TM-281A cant set memory channels
Great to hear you have resolved the issue, Jason.
Cheers,
Peter
Aug 16, 2012 | Kenwood Tm-281a Vhf 65 Watt Mobile Two Way...
What has happened to my old RCA TV??
The issue has to be (HAS) the set is in the cable band.
Mar 31, 2012 | Televison & Video
LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT
The manual isn't online to my knowledge however I did find a guide on how to program it.
"Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
"E." Press "REVIEW" at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the LED readout
display, you might be entering an invalid frequency. Refer to the list
of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push
"E." Push "MANUAL" to step to channel three. Repeat this process until
all the (10) channels are full, or you've run out of frequencies to
enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)"
http://newsgroups.derkeiler.com/Archive/Rec/rec.radio.scanner/2006-01/msg00174.html
Hope this helps.
Apr 22, 2011 | Office Equipment & Supplies
There no sound coming from my main and center speakers also cant figure how to used da coupler set up
The manual is apparently non-existent online so I only have this pitcure to use for reference... http://www.canuckaudiomart.com/view_images.php?cat=Amplifiers&catnick=amplifiers&cfid=113149&image_id=837646
The jumpers must be in place for tthe internal amplifiers to use those channels. Removing them allows you to feed external amplifiers to drive those channels. Lacking the original jumpers just place some short RCA cords in.
Dec 12, 2010 | Yamaha DSP-A1000 5-Channel Amplifier
Don't have a manual or the remote for KLH audio video receiver model r5100. Cannot figure out how to program the presets on the am/fm radio. Can someone tell me how or do I have to have a rermote to...
There should be numbered buttons on the receiver.Set the channel to what you want to preset,then press and hold down the numbered button you want.The sound will probably go away for a couple of seconds but when it comes back on the channel is preset.If you press the band button while you're already on FM and it goes to another FM,you can also preset more channels for FM.There should only be one AM band,then it will switch back to FM.
Good luck! Greg
Aug 10, 2010 | KLH R5100 Receiver
I cannot figure out what setting to put it on to oick up all it capitable of picking up its on 50 mhz now all get is the local area will you help me with this problem as I spent all my money on buying it...
Sorry, but there's no simple answer as channel spacing varies with frequency/band. The majority will be using 5.0, 10.0, 12.5, and 25.0 KHz steps within the USA, but you'll have to experiment with each band. You're skipping over most VHF and UHF signals using the current 50.0 step setting. The R5 is a wide-coverage receiver with lots of features, but the manual leaves a lot to be desired, the receiver is missing features like automatic step selection (found on almost all scanners), and operation can be extremely difficult. Much of your use will involve interpreting the manual and experimentation.
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Dec 29, 2009 | Icom IC-R5 Handheld Scanner
Clear all the pre-set channels
There's no clear all settings there. You need to manually delete each saved station. Try to unplug the power of the unit for few hours and check if that clears all.
Mar 16, 2009 | Aiwa Audio Players & Recorders
Car Audio & Video Logo
95 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
