Question about Zanussi FJS1225W Front Load Washer
No spin hello,our machine is 7 yrs old and has decided to stop spinning, it fills with water and drains, nut drum does not rotate at all, belt seems fine, please help, 3 young kids and footballing husband, i.e loads of washing
  • gendo Dec 11, 2007
    hi, thanks for replying so quickly, wheres the best place to get them from, are they expensive?, thanks
, Hi , My Zanussi Aqua Cycle 1000, Wash cycle (s) appear to start and run as normal, however the the Spin cycle does not kick in, it seems to try, both long and short spin functions have the same problem, also when I set the dial to spin out side of a wash cycle the result is the same , ie it trys to spin but fades after scaling up to very low revs....any ideas, could it be the Carbon brushes? if so are they easily obtained and fitted..Thank you
Posted on Aug 28, 2011
  • 139 Answers
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Posted on Dec 11, 2007
My 10+ yrs old Frigidaire gallery # GLTF1240AS front-loader drum won't agitate/spin
Check and see if the drive belt broke? On mechanical agitators using gears, a solenoid may fail and drive motor won't function.
Dec 23, 2013 | Frigidaire Washing Machines
Frigidare gltf1670as
You likely have a broken or slipped drive belt or broken spring on the belt take up arm on the drum. Appliance has a lot of DIY instructions on how to get at the belt and make repairs.
Jan 23, 2018 | Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Drum not rotating on washing machine
change the carbons in the motor
Jun 28, 2010 | Washing Machines
Washing machine will fill with water, but won't spin.
hi there.
If the washer won't drain or spin there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014
SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...
or go to this link for more help.
Washing machine will fill with water but won spin Google Search
Nov 18, 2017 | Whirlpool 3.2 cu. ft. Plus Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Why wont my washer dryer empty the water...???
If the machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is okay (though some units have a separate belt for the pump and direct-drive washing machines don't have belts). 1) Be sure the drain hose isn't kinked. 2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The water pump may be broken or clogged with a small article of clothing or the controls may be broken; call an appliance repairperson. courtesy "nagev"
Oct 24, 2006 | Hotpoint Aquarius WD63 Front Load...
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
572 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
