Question about D-Link DFE-530TX+ Fast Ethernet PCI Network Adapter
Installed d link eithernet 10/100 adapter on a Pentium 3 machine running win nt 4.0 need help setting the parameters for it to work correctly.
  • ikkenom May 11, 2010
    This is a "plug-and-play" device, but Windows NT 4.0 (which Microsoft no longer supports) did not have much "plug-and-play" support. Which IRQs is your system currently using? Which I/O ports (220? 230? 240?) are available to be used?
    President:
  • 392 Answers
Install the drivers and then configure , it with the IP address given by ur ISP. If your ISP is having DHCP enabled , then no need to enter the IP address .
Posted on Sep 11, 2009
I am living in Argentina I buy a Melnor Yardworks model 59-7470-0 in Canadian Tires in Canada Unfortunly the treads conectos are of difernt that we have commoly here for example Gardena and others...
This is not going to be an easy 1:1 conversion
I believe Argentina uses BSP British Standard Pipe
Unknown what thread is used for water hose in Argentina.
US sold products use NPT tapered pipe thread
US has different-but-similar thread for water hose.
So you need at least 2 adapters:
Adapter from 3/4" BSP to 3/4" NPT.
And then adapt 3/4" NPT to 3/4" hose thread.
And then possibly another adapter to hose thread in Argentina.
There is no immediate link announcing which vendor sells BSP to NPT adapter fittings, in Argentina.
However, the following link sells adapters, in Australia:
http://www.irrigationwarehouse.com.au/category2_1.htm
You can google the following search parameter in Argentina:
Adapt NPT pipe thread to BSP pipe thread
Issue is compounded with 2nd adapter problem.
Melnor sells water timers that screw onto a hose bib.
3/4" hose thread is different than 3/4" NPT pipe thread because 3/4" pipe thread is tapered, while hose thread is straight with no taper.
When connecting a water timer to hose bib, the seal is made with rubber washer.
Home centers in US sell 3/4" NPT pipe thread to 3/4" hose thread.
http://quinbyhardware.com/Products/SKU/4294278/3-4MHX3-4MIP-BRASS-CONNECT/LAWN-and-GARDEN/WATERING/GILMOUR-MFG
You can google the following parameter, but sources might not be in Argentina: 3/4" hose thread to 3/4" pipe thread
Sep 04, 2011 | Hardware & Accessories
Wireless adapter tp-link tl-wn321g dont install into win xp sp3---please send driver
There are 4 different versions op the TP-Link TL-WN321G.
Look on THIS PAGE how to find the version and download and install the correct driver.
Aug 31, 2011 | TP-LINK TL-WN321G - Network adapter -...
Not connect from console port
Verify that the correct settings and cable/connectors (rollover cable, correct COM port specified) are being used when establishing the console connection.
From the manual-
3.9.2 Connecting to an IBM or Compatible Device
To connect an IBM PC or compatible device, running the VT terminal emulation, to an
Enterasys Networks module Console port (Figure 3-20), proceed as follows:
1. Connect the RJ45 connector at one end of the cable (not supplied) to the Console port on the
Enterasys Networks module.
Connecting to Console Port for Local Management
Hardware Installation 3-31
2. Plug the RJ45 connector at the other end of the cable into the RJ45-to-DB9 adapter (supplied
with the device).
3. Connect the RJ45-to-DB9 adapter to the communications port on the PC.
4. Turn on the PC and configure your VT emulation package with the following parameters:
Parameter Setting
Mode: 7 Bit Control
Transmit: Transmit=9600
Bits Parity: 8 Bits, No Parity
Stop Bit: 1 Stop Bit
source: Install Guide for Enterasys 1H582-25 / 1H582-51 (http://www.retrevo.com/support/Enterasys-1H582-51-Switches-manual/id/2785dj098/t/2/)
Jun 22, 2011 | Enterasys MATRIX E1 (1h582-51-g)...
My win 7 os cannot recognized the crusb10075 3com adapter.
1. Don't plug your WLAN USB adapter until setup finish and reset the computer
2. Download XP driver from 3COM in below link... make sure to select the correct one depending on the serial number of your adapter (starting with 0100/0200/0300)
http://www.wireless-driver.com/3com-officeconnect-wireless-54mbps-11g-compact-usb-adapter/
3. Double click and it will automatically unzip and may ask you again after unzip use recommend settings and click yes to use recommend settings and click yes to all to overwrite again the folder unzipped again but if didn't ask it is OK.
4. In the unzipped folder right click on the setup file and click properties then go to Compatibility tab. InCompatibility mode click "Run program in compatibility mode of" then chose Windows XP (Service Pack 2) and OK.
5. Click setup now and after installation finish restart your computer.
6. After reset plug you USB adapter and will take some time to install the driver.
Apr 20, 2011 | 3Com (3CRUSB10075) 802.11g/b Wireless...
When i install the drivers for TP-Link WN353GD adapter, I already get a warning that it may not be compatible with my system. Currently i am running Win XP SP 2. Is there sometime i can do to overcome...
Update your Wireless Adapter firmware @ http://www.tp-link.com/support/download.asp?a=1&m=TL%2DWR340GD
There are 3 versions for your product(TP-LINK TL-WN353GD, Important***select the correct firmware version to update. Then download the latest drivers(Setup Utility) & and install the drivers for your adapter from the TP Link site.
Link - How to look over the hardware version on a TP-Link device?
Hope it helps.
Apr 05, 2011 | TP-LINK TL-WN353GD 802.11g/b Wireless...
Im looking for D-Link DE 220PCT driver for win nt
though i need to know the os platform u r using..
considering that u r using win xp or vista..
howevr,along wid the company, there will b a list of such site ndriver download links if u search by the model name on a search enginelike google..
download them onto a location; if the driver is in azip format, unzip it,if itz in .exe form, just run it; if done manuallyit'll ask for the correct driver and location; relocate the path anda.inf file (wat it'll ask for)..
try downloading..
http://driverscollection.com/?H=DE-220PCT&By=D-Link&SS=Windows%20NT
but always better to consult ur system admin/vendor....
Nov 11, 2009 | D-Link DE 220PCT Network Adapter
Frogger for Windows 97
As far as I know, the music does not play on a SATA drive, or on a NT based operating system. It seems to only run on the DOS based operating system, like Win 95, 98, 98SE, and ME. Frogger works fine (with music) on my older Pentium 4 with Win 98SE.
Nov 07, 2008 | Video Game Consoles & Games
Hello.......
since you are using an obsolete model and computer specs, i don't think this can actually support windows XP in optimal settings.. You might want to install windows 98 on this machine to be able to use it properly.
note: you may think that this machine is working really slow because you tend to compare it on the newer machines that you are using. If that's the case, then you are definitely right that it's slower. This is because the machine is really old. KUDOS to you though for having a working machine that is this old. I used to have one about 4 years ago and it was one of the best during its time. :)
Sep 13, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
System Error. Code : 87. Parameter is Incorrect.". Please give me solution for this
When I want to connect a software ,which connect to Database through ODBC display the messageV"System Error. Code : 87. Parameter is Incorrect.". Please advice solution
Mar 29, 2008 | Microsoft Windows 98 for PC
D-Link DFE-530TX+ Fast Ethernet PCI Network Adapter Logo
114 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
