Question about Canon PIXMA iP1800 InkJet Photo Printer
I am getting the warning "Ink absorber full". Is there anythinh I can do on a DIY basis?
  • 1 more comment
  • romid Sep 11, 2009
    Hi sorry to sound so stupid but I cannot get printer head to remain in centre or at extreme left. What am I doing wrong?
    Hi soloved the problem of absorbiing the ink but now when I go through the procedure of resetting, on power up the lights flash as follows:
    Green light 14 flasshes
    Green light off
    Reset light on with eight flashes
    Reset light off, green light on for one flash
    Green light off
    Reset light on with eight flashes etc....
    Any ideas? Thanks.
  • romid Sep 12, 2009
    Hello again still lno solution to problem -
    have followeed your instructions to the letter but there is now a slight change:
    when pressing the power on button and pressing and holding the reset button the reset button light immediately comes on and I press the lighted button twice and release both.
    The reset button light goes out and the green light flashes as printer goes into service mode. The green light continues flashing and even if the reset button is pressed 4 times the sequence of one green and eight reset lights continunes until reset button is then pressed once. The green then becomes steady, however on starting to print the error message "ink absorber full" comers back on. complete with reset light. To print, reset button has to be pressed so we are back to square one again. Is there anything else you can think of to rerset thew system. Does the flashing reset light on 8 flash cycles tell you anything. Sorry to be a pain. Best wishes.
    Problem Solver:
  • 9 Answers
We are end users who solved this problem successfully, no thanks to Canon. The solution is too long to post here. Please visit our safe and virus free site below. Thank you.
http://country-cabins.com/IP1800.html
Posted on Jan 10, 2010
  • Sonya Finkey
    Sonya Finkey Oct 19, 2013
    10-19-2013 we regret to inform you that we have taken down our company website at country-cabins.com. The solution was to take the printer apart, clean all the parts and reassemble it again. Then it had to be reprogrammed. It was basically more trouble than it was worth, but extended the life of the printer another three years.
  • Canon Master
  • 13,433 Answers
Ink absorber is a pad under the print head area, in the bottom fo the printer that collects excess ink from the machine.
The machine will need to be taken apart, you need to remove the old ink absorbers either wash and dry them for few days and then replace them into the unit or puchase new ones.
After that is done the waste ink counter will need to be reset.
Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
if that doesn't reset it look for other suggestions at http://www.fixyourownprinter.com/forums/inkjet/52198
and google - http://www.google.com/search?q=PIXMA+iP1800+ink+counter+reset&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:fi:official&client=firefox-a
Or to save some fustration and headache just take the machine to canon service center to get it serviced, the end result will be much better.
Posted on Sep 12, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Open the cover, move the cartridges to the centre, and then press the pad of absorbent paper towel onto the waste ink pads. You can locate the waste ink pads to the right of the cartridges. This will absorb a lot of ink in the pads and that will remove the warning after you reset the printer waste ink tank counter. You can reset your Canon Printer by following this procedure—
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button 4 times for waste ink counter reset.
5) Turn off the printer.( it must be turn off) then turn it on again.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 11, 2009
  • Rylee Smith
    Rylee Smith Sep 11, 2009
    Please turn off the printer before you bring the printhead in the center. After this is done you can follow the procedure to reset the waste ink counter--
    Thanks
    Rylee
  • Rylee Smith
    Please follow the exact procedure as mentioned. Check if in the first step you pressed the power button while the printer was off but plugged into a power source. Try to reset the printer 2-3 times if you are unable to reset it at once.
    Thanks
    Rylee
I have a canon MP520 - its been warning me for quite a while that the absorber is almost full. Now it has stopped working at all - saying that the absorber is full. How can i clean the waste...
There are ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head moves to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Jun 02, 2011 | Canon MP520 All-In-One InkJet Photo...
My printer says ink absorber full is there anyway to reset counter
When you insert a refilled ink cartridge into your printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won't get the warnings again because the ink levels won't be monitored by the printer.
May 16, 2011 | Office Equipment & Supplies
Canon ip90 waste ink absorber warning
Not all the ink that leaves the ink-cartridge gets jetted onto the paper; some of it is "wasted", and goes into the "absorber".
So, the software inside the Canon printer has mathematically predicted, given the number of pages you have printed, and the number of times that you've turned the printer off, that, statistically-speaking, the "waste ink absorber" is almost full.
Take the printer to a qualified printer technician, for replacement of the absorber, and to "reset" the electronics to "zero pages printed".
Oct 04, 2010 | Canon PIXMA iP90v Printer
I get a warning that my "waste ink absorber almost full". How do I empty it?
Can you tell me what unit is your canon printer?
Because there are two ways to clear the waste ink absorber full in your printer.
First, is by actual cleaning of the ink absorber pads that is seated under the ink cartridges in its home base position. Remove the waste ink from the foam / pads by a running water.
Second, is by a reset procedure..but I cannot give you the exact reset procedure because you did not mention the model of your canon printer.
Please reply back so I can help you further.
Please rate this answer if were done with your solutions.
Thanks.
Aug 25, 2010 | Canon Office Equipment & Supplies
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer shows warning
plz check the website http://www.fixyourownprinter.com/forums/inkjet/50418#1
Nov 18, 2009 | Canon PIXMA iP2000 InkJet Printer
I am getting an 5800 error
Ink Absorber Replacement OptionsThis printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to release the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk
the 5800 code. uplug cord from outlet. wait 1 full min, then plug in and let go through self test.
reply for more help.
have a great day and please rate bama46, thank you
Aug 17, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cartridge jammed / Waste Ink absorber almost full
Waste ink pad or pads are full and need changing.
Under your ink carraige cradle it is,
It will be full, bit of a dirty job.
Hope this helps
Ric.
Apr 17, 2009 | Office Equipment & Supplies
Waste ink absorber is full
Ink Absorber Replacement Options: Info can be found HERE !!Read Thouroughly!!
!!! READ Carefully the options Listed at Canon's Website
!!! in the Link Above BEFORE looking at the following Links:
-FixYa- Troubleshooting Topic (Same concerning Topic) with (SOME) useful information on your above concern.
  • [ Mostly Temp Fixes ] -in The Above Link. And there Are procedures for these, described there as well.
Actual DIY Procedure: I found this on Yahoo!Answers. BE ADVISED. Hopefully you've READ ALL the info regarding the Ink Absorber Replacement Options in the info Link I provided Again Just now, and above (AT CANON's Website)
I'm only providing some incite and knowledge as to what your options are, and, I, am not to be held responsible for any damage that may be done to your printer in the event of you Attempting the DIY Procedure.
I Hope This Helps.
I hope All Goes Well.
Jan 21, 2009 | Canon PIXMA iP1600 Printer
Waste ink absorber full I get a warning dialogue saying the 'Waste ink absorber is almost full' Press resume to continue. Solution would be appreciated. Many thanks.
Thanks for posting in FixYa.
It may be the problem arised due to installation. Also check the device manager for any flag coming.
You need to go for reinstall the printer.
Let me know if you need further assistance.
Have a Nice day. Dont forget to vote me.
Regards
Ellin
Sep 13, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon PIXMA iP1800 InkJet Photo Printer Logo
862 people viewed this question
old marine
old marine
