Question about Dell A940 All-In-One InkJet Printer
Dell AOI A940 is note feeding paper through
My Dell AOI A940 printer will not feed paper through. It will pull paper down, but will not feed it through. Then tells me I have a paper jam. It does not matter what type of paper. Please help!!
My AIO 940 printer does not pull paper properly to print, it does not pull one side of the plain paper and creates a paper jam.
I was having the paper pull to the right. I opened the cover to expose the ink carriages. I found sticky black ink on the platform under the ink. I used a towel and rubbing alcohol to clean off any excess ink. I believe that the sticky ink buildup on the left side did not allow the paper to feed properly. All seems to be well. Hope this helps.
Feb 26, 2011 | Dell A940 All-In-One InkJet Printer
Paper feeding problem
Sounds like the rollers may need to be cleaned, take an older rag and wipe down everything and also check for jammed paper in the printer.
Let me know how this goes and if this doesn't fix it, then we can see what else could be wrong
Jun 05, 2008 | Dell A940 All-In-One InkJet Printer
Dell A940 printer will not pull down,or start
I got it fixed........But if I told you how...I would need to charge you $6.95 per month.
Dec 24, 2009 | Dell A940 All-In-One InkJet Printer
The papaer is not feeding well on both sides therefore it sticks during printing.The right side of the paper feeds quickly and stiks. I have a dell all in one A940 Thanks Undine Wooding
looking at the pictures i would say the paper feeds in from the top turn the printer upside down and shake it there could be something fallen in there and is cause the paper not to feed on the one side.
Sep 02, 2009 | Dell A940 All-In-One InkJet Printer
My a940 will not feed the paper. the error message
Here is the Dell support page the gives instructions for this errror, (though not overly helpful, I'm afraid.) See also instructions here, here, here,
If none of those steps correct the problem, reset the printer by following these instructions.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 25, 2009 | Dell A940 All-In-One InkJet Printer
Paper feeds to the right and Jams
Sounds to me like there is something in the paper chanel, a staple, paper clip or something small enough to get in there. Have you tried turning the printer upside down and lightly tapping the side to see if anything falls out?
Mar 14, 2009 | Dell A940 All-In-One InkJet Printer
Power light blinking but cannot switch on
Usuall the power light will blink if the paper fails to feed or is out. After putting more paper or straightening the paper out after a miss feeds, you usually have to press the on/off button so the printer will recycle and start printing.
Hope this helps. Bud
Jan 10, 2009 | Dell A940 All-In-One InkJet Printer
A940 doesn't feed paper correctly
My DELL A940 printer used to jam every time with the paper pulling to the right.
Solution - there was a pen jammed in the mechanism !
I was about to trash the printer when I looked deep into the workings from above, holding the printer to the window to get bright sunlight into it. I could see a round ballpen laying in the groove at the bottom.
Hooked the pen out and all is back to normal.
This may not be your problem, but its worth a look.
Dec 26, 2008 | Dell A940 All-In-One InkJet Printer
A 940 paper feed problem
Dec 28, 2007 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
152 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
