I CHANGED THE BLACK IN ON MY CLX 3160 AND NOW THE SOME PART OF THE PRINT OUT IS FADED. TOOK OUT THE INK CARTRIDGE. GAVE IT FEW SAKES AND PUT BACK IN. SAME PROBLEM. PLEASE HELP
If your printer prints like this with faded or uneven print,
The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
I'm not sure if it is a similar problem but I have a CLX-3170FN and it has started to run a strange line down the page, and part of the page was smudged. I cleaned it all out and looked at the drum etc and it was all fine. Then I spotted there is a plastic belt that must run like a conveyor belt behind the drum and there is a split running along it - Found out it is called the transfer belt. It was difficult to see which I why I am suggesting it to you. Now I just have to find how I can replace mine. :)
Go to printer properties and check whether you have selected print in grey mode and also check whether you have selected the economic mode. Rectify the same will solve your problem.
This is a very common problem with the Samsung CLP 300 and CLX 3160 printers. What happens is that the toner or developer blades become coated with toner. The developer blades meter the amount of toner that the printer uses to make the image on the paper. When the blade become blocked, the image become faint. To fix this problem, you and either replace the imaging unit for about $100 or you can clean the blades yourself. I have posted instructions how to clean them on my Tips section.
If the problem is only with Black output you need to change the Black developer of the Imaging Unit, Else you need to refer to the Authorised Service center. Else you may change the complete imaging unit by yourself.
Providing that the ink cartridges were new and supplied with the printer, the cartridge is defective. I also don't think that you used up all the ink either unless you printed hundreds of documents already. Take the cartridge back to the store where you got the printer from and they should give you a new one.
