Question about Kenmore Refrigerators
Case between doors and down left side is hot to the touch
  • 60 Answers
This is common during the defrost stage. IF melt all the ice and drains it to the bottom of the self defrost pan. Your fridge goes on sycles to clean itself. IF it is hot all the time then you may want to call sears to confirm if there is a actual problem or not.
Cheers
Allen
Posted on Sep 11, 2009
Power windows not working
1 does the led's light up on the master window switch [drivers side] 2 when you rocker the drivers side down can you hear a audio click down under the steering wheel. the i/p fuse panel is down there where you rest your left foot.3 power is from battery saver relay to master ins. relay to one touch window relay. this is the one you should hear click. the back side of this fuse panel calls out the locations down there. the owners manule also helps some.4. if you take the interior door cover off remove the screw on extenstion on door lock and one screw under plastic button where you pull the door shut.arm rest support bracket. the rest is held in place with snap in plastic buttons [christmas trees like]. the door latch unlock should slide out of the opening when you slide it froward.there are 4 male/female electrical connections, 2 to the master door switch.one to the power/heated mirror, 1 to power locks. 5. don't unsnap them yet.with a test light you can check for battery voltage. on the master door switch the blue/black tracer wire should be hot[12 volt dc]. at all times. put one end in the backside and the other to a bolt or rivet on the door. the light should come on.next with one end on the blue/black tracer and one on white/black tracer rocker driver side up/down switch, the light should come on.there are only 13 wires on the master window switch 2black wires are ground, 2blue/black tracer[hot] 1 red/blue tracer should be [hot] when you unlock the window lock rocker switch.know the passanger and back seat switches should work. switch it to lock and they should only work from the driver side master switch.the 8 wires left are 2 for each window one up one down.try this with a friend it makes it easyer. good luck doug.
Sep 10, 2012 | 1997 Ford Taurus
Side by side getting very hot on top left side of freezer and between the doors where the door liner touches the frame
Not quite sure about top left side, probably normal.
But the hot door liner is definetly normal, this is so the liner remains plyable and doesn't freeze to the frame.
Fuji
Aug 06, 2009 | Refrigerators
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Door seals are hot to the touch..
The door seals are heated to prevent freezing.
Jun 22, 2017 | Refrigerators
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
1998 buick park avenue drivers side blows cold, passenger side hot
sounds like the drivers temp door actuator is not working should be located on the drivers side of the air box down by the gas pedal or center dash area
Oct 03, 2008 | 1998 Buick Park Avenue
Space between doors on cabnet is very hot to touch ref seems to work ok
hi. thanks for the question .the heat between the doors is normal . its hot to keep condensation from running down the doors .but pull fridge away from wall. remove back panel and clean all the coils. very important. thanks the appliance doc
Sep 30, 2008 | Maytag 23 cu. ft. Side-by-Side...
Fridge is getting hot in between the doors
This is called a mullion heater and is perfectly normal as this heater prevents the area between the doors from freezing. No danger at all.
Mar 08, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
