When I print several pages, I want page 1 to be on top instead of printing page 1 first, face up then I have to go through and sort them. I have a KM 6330 copier.
    Brigadier General:
  • 4,044 Answers
In the copier menu there should be a selection to reverse the print order, if the copier has that ability. If this is a printer you can make this selection in windows by selecting print from the menu instead of using the print button. Basically you are telling the computer to send the pages in reverse order.
Posted on Sep 11, 2009
How do I Print double side on wireless printer
unless you a specific printer that can print double sided in one run
you have to set the printer manually
to do this when you go to the print command , it will show up as print all, print pages etc
click on print pages then type in 1,3,5,7 each number has to be followed by a comma until you get to the last page or click on print odd pages only
then print what you want
when finished pick up all of the printed pages and put them back in the tray upside down with the top facing in the right feed direction
then go back to print all pages 2,4,6 etc or print all even pages then print
if you are not familiar with that procedure , practice on a couple of sheets until you get the way the pages face correct
practice by opening a new document and just typing a few words on the page 1 and 2
then print it out
Apr 02, 2017 | PRINTER Office Equipment & Supplies
Kyocera Mite KM-1510 printing on half pages instead of full pages
It sounds as if the paper size at the machine is set incorrectly. Try checking to ensure you cassette or bypass if that is where you are printing from is set correctly.
Feb 16, 2010 | Kyocera Mita KM 1510 Laser Printer
My Brother HL1230 printer prints with whole lines of text missing several times on a page and gets worse by missing more lines if printing several pages. It has a new toner cartridge. How can I sort this...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother HL 1230 Laser Printer
My Hp PRINTER just started printing 1 page on to multiple pages ?
check paper size settings on both your pc and printer manu.
Sep 30, 2009 | HP Office Equipment & Supplies
Printer starts out printing page two instead page one on atwo document
That's a setting in printing preferences. It will print from back to front so that the top page is page number 1.
Sep 24, 2009 | HP PSC 2175 All-In-One InkJet Printer
Copier km-c2525e will only print 1 page of document
Hi
it might be a long shot but have you got an add toner message on your copier screen.
When toner is required the copier will only print on page at a time.
Alternately you should ensure that you have not selected a partial print  eg
print current view or print current page.
if all this fails, reload the driver and or your Acrobat reader
hope this helps
Aug 14, 2009 | Kyocera Office Equipment & Supplies
Printing gibberish then feeding several lines, printing gibberish
If text did not line up as planned, your TOF ( top of forms adjustment ) isn't correct. Just correct it using the button on the panel. If after printing 1 page or so and then it begins to go out of place, most probably you hv set the page lenght incorrectly. To correct, enter the MENU on the panel and set the correct page length.
Lastly if printing garbage, most probably you have selected the wrong emulation on the MENU. Correct by entering MENU mode ( press ' SHIFT+MENU ' button together ) and select the correct emulation.
Hope this helps.
KM HOO
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
HP 1300 printer prints 2 or more pages into 1 page.
Is it actually printing 2 pages on top of each other or is it 1 page with shadows on top?
Oct 24, 2008 | HP LaserJet 1300 Printer
Printing
Dear jamin4volks;
As per this excerpt from the Oki B4350 User manual:
"FACE UP AND FACE DOWN PRINTING
For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
Hope this helps;
Frank
Apr 18, 2008 | OKI B4350 Laser Printer
44 people viewed this question
jasbo
jasbo
