Question about HP OfficeJet 7110 All-In-One Thermal Printer
Same 'scanner failure' message + color is not working well
Color cartridge is full; only printing orange/red
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
I replaced all 3 color cartridge with origanal hp products, even after calibrations (3 times-full mode) only cyan and black are printing nicely. red and magenta colors are not printing.this is not driver...
This is a common problem with this model of printer. The scanner optic degenration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colours shift: purples turn blue and oranges turn yellow. The printer optics will need to be cleaned by a technician to resolve this issue as it means dismantling your printer deep into the optics to fix the problem.
Jun 07, 2010 | HP LaserJet 3600n Printer
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Cartridge Error
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
Error 50 c
  1. Power off your printer.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Hope this helps.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Ink cartridge problem
Mar 18, 2008 | Lexmark X6150 All-In-One InkJet Printer
Trouble code
Oct 23, 2007 | Lexmark X5150 All-In-One InkJet Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
105 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
