Question about Swanson Speedlite Level Square
Need to know how to figure a rafter cut
I have a Swanson Square and need to know how to use it to figure the degree of angle to cut.
  • 142 Answers
Assuming you already know the angle you require, take the edge with the level on it(if you have that model) or the side that hangs over and hook it on the edge of the board. If you look at the top, on the 90 degree end, it says "pivot", and that is where you will spin the square around. You read on the 45 degree end that was hooked to the board for you angle. If you are trying to cut a rafter at a specific pitch such as a 6/12 you will spin the square around until the 6 on the Common scale lines up with the edge of the board. The Hip/Val scale is for cutting hips and valleys for the roof structure.
If you have any other questions, feel free to contact me here
Bob
Posted on Sep 19, 2009
How to cut wood trim corner angles ?
It's generally easiest not to figure them at all - prop them in their intended position (although usually upside-down) to make the cut. Doing that eliminates any need for a compound miter saw. That assumes you're talking about crown molding. If you just want the angles for flat moldings, then remember that a square corner equals 90 degrees. Split that corner in half to make a miter joint, and you'll want 45 degrees. If you're making a half-round corner with three pieces, split the 90 degrees by three (the number of pieces) and you get 30 degrees each.
It does get a little more complicated if you're meeting one thickness molding with a completely different thickness molding - then sometimes the easiest thing to do is not miter at all, but make a "coped joint".
Jul 12, 2014 | Office Equipment & Supplies
Do you lay the handle long wise against the wall or the end of the handle??
A sliding bevel is used for transferring an angle. What matters is the angle created between the handle and the slider. For example, if you wanted to cut a piece of wood to fit in a corner but that corner is not 90 degrees true. You would loosen the nut, place the center of the bevel in the corner so the edge of the handle lays flat on one wall and the edge of the slider is flat against the other wall. Tighten the screw on the bevel. Now you can lay the bevel on the piece to be cut and mark the exact cut line so the finished piece will fit perfectly.
The sliding T bevel can also be used for setting an angle by using it with a protractor. lay the bevel on a protractor, lock the screw in place at the desired angle, then lay the bevel on the work piece and mark the cut.
Dec 31, 2010 | Swanson 8 Inch Sliding T Bevel
I have a 12" Craftsman Band saw and the blade keeps coming off. What adjustments do i have to make to put on a new blade and keep it on?
The wheels have to be true at 180 degrees facing each other. Use a metal rafter square if needed to align the trueness of these wheels. If one is angled out ward the blade does come off the wheel
Jul 06, 2010 | Saws
When I try to cut a 45 it seems to be cutting a little more than a 45. how do I adjust it?
Make sure the blade is 90 deg vertical to the saw table. Make sure the indicator is set approprately. Raise the blade just enough to clear the table/base. Place a swanson speed square against the fence and blade. Make sure the indicator is at 90 degrees. Here you might want to tilt the square and check that the complete blade is flush against the sqaure as high up as possible. Lay the square back flat on the table and pull the blade toward you as much as possible. The teeth on the blade should ride against the square extented completely out.
Now set the square against the fence with the 45 degree angle coming away from the table and set the blade on the 45 deg mark on the insicator scale.
The blade should touch the square all the way out fully extented.
Or just experiment with some scrap and check
May 19, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Directions on how to use a square to cut common rafters we have a stanley squ and no manual, on use
A standard square is used primarily for drawing 90 degree angles. Simply hold the fat side of your square firmly against the length of rafter. The skinny side of the square should be lying accross the rafter, forming a 90 degree angle with the side. Use a pencil to draw a line along the edge of the square and use this line as a guide while sawing the rafters.
Sep 27, 2009 | Carpenter Stanley 45-500 Handyman Steel 's...
KNOWING RISE OVER RUN HOW DO I USE THE SQUARE TO MAKE MY ANGLE?
Run is alway 12".
Example 4" (rise)/12" (run)
Measure 4" on one leg of the square and 12" on the other leg. Connect the points and there your angle.
Jun 29, 2009 | Swanson 119 High Visibility Speed Square
How do I use an 8" T bevel?
put it against the wall so it touches both walls. Then lock it in place with the nut. Next if you have a power miter saw lay it on the table and move the blade so it lines up with the angle thay you have then it will give you the angle for the cut.
Good Luck
Dec 28, 2008 | Swanson 8 Inch Sliding T Bevel
Grinder problem
* The base plate can be tilted to make angled cuts. Most saws adjust from 90 degrees to slightly less than 45 degrees, making it possible to cut bevelled ends on boards for corning attachments, hip-roof rafter cuts, and even miters. Most saws are equipped with a thumbscrew or lever to loosen the bolt which keeps the saw blade on the correct angle for the cut you are making, located on the front of the saw. Some are also equipped with a scale which indicates the blade angle, from '0' (90 degrees, or square to the board surface) to 45 degrees. * The blade can be set to the depth required for individual cuts, from less than 1/8 inch to the full depth the blade is capable of penetrating. The lever or thumbscrew which locks the base plate at the desired height is usually located at the rear of the motor on the left side. * Many circular saws are equipped with a ripping fence, to guide the blade as you make a rip cut along the edge of a board, giving you a straighter, parallel cut. * Dust ejector. A few newer saws are equipped with a dust ejector to blow the sawdust away from the operator's face and from the mark where the cut is being made. * Laser tracking light. Some newer saws are equipped with a laser that projects a bright, red line down the path of the blade travel. These can also be purchased to retrofit on older units that are not factory equipped with them. * Blade guard. This should be considered a essential safety feature on any saw, and has two parts, the fixed guard over the top of the blade, and the floating guard, which rolls out of the way as the saw is pushed into the work piece. Some have a handle so the blade guard can manually be lifted for plunge cutting or easier viewing of the cutting mark.
Aug 27, 2008 | Speed CGW ABRASIVES 35587 "24-GRIT" HIGH...
Swanson Speedlite Level Square  Logo
369 people viewed this question
Top Swanson Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Swanson Measuring Tool and Sensor Expert? Answer questions, earn points and help others
