Question about E-Machines eMachines Desktop PC
El1200 Get error that says DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER. crankstart said he had instructions he can email to make the recovery DVDs. I can see the HD in another machine. Please email to ed at aonecomputers dot com. Thanks.
  • ed72239 Sep 12, 2009
    Disk boot failure is a hard drive failure not a cdrom problem. I did disconnect the CDROM to insure it was not locking up the bus. The hard drive is probably bad and would just like to try to copy the recovery data to another HD and run it to create the recovery DVD set as crankstart mentioned. I know I can order the DVDs but the customer is in a rush.
  • 674 Answers
Use another cd room or..change your installer..
Posted on Sep 12, 2009
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
Getting message "Disk Boot Failure Insert system disk and press enter" using window xp platform and have MCA fee antivirus software
this happens either the boot sequence have changed or your hard drive is not recognised by the BIOS
Jan 26, 2013 | Computers & Internet
When i turn on my PC toys CPU and emachines monitor it says disk boot failure enter system disk
hi,
you have two option as follows:
1.when you start PC press F2 enter in BIOS set it to boot from HDD then restart,if this step does not help then number 2
2.reinstal the OS
Sep 26, 2012 | E-Machines eMachines Desktop PC
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
Asks me to When I run my recovery disk that Acer sent me this is what occurs, System disk runs and loads fine I F12 as instructed by Acer and then wait Asks what language I want instruction in I choose...
Either you DVD is corrupt, OR the DVD reader is not working correctly. It seems the reason the restore failed, is that it "Thinks" the Hard Drive is corrupt, too corrupt to replace the OS on...
The only thing to try now, is to get a Windows install DVD, put DVD in drive and boot from the DVD, then try to install with that, when you get to installing and it asks if you want to Format, do so, format Full NTFS. Then try to proceed to installing. If this too fails then you will need to replace your hard Drive, quite a simple matter.
Mar 06, 2010 | Microsoft Windows Vista Home Premium with...
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Boot disk error insert system disk and and press enter.
it is a hard disk error. most likely your hard disk is defective since is it not registering well. please try to use 80-pin interface cable to correct the problem or change your Hard Disk
Sep 21, 2009 | ASUS P4S533-MX Motherboard
Disk Boot Failure
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Aug 08, 2009 | Computers & Internet
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
E-Machines eMachines Desktop PC Logo
217 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
