Question about Estate TEDX640JQ Electric Dryer
The dryer cycle is not working. It stays still instead of going around.
  • Michael Masters
    Michael Masters May 11, 2010
    Are you referring to the dryer timer module, or the drum itself?
  • 60 Answers
Ok but is it making any kind of noise? If it is making a noise then you will need to possibly replace the belt. call your authorize technician to replace the belt and they can also check and clean you lint traps and the insed of the unit.
Cheers
Al
Posted on Sep 11, 2009
LG dryer doesn't dry clothes on one cycle. Lint collects around bottom of door rubber seal. Have noticed, the door is not closed tight. How to get door to stay closed tightly?
It sounds like you have a plugged up vent causing air to try to blow out around door instead of out vent. Also check door latch to see if anything is broken.
Mar 28, 2016 | LG Dryers
Element turns on even if door is open. at end of drying cycle drum shuts down but element stays hot
Your problem is usually caused by a bad/broken heating element. What happened is the element broke or burned apart at some point and the broken end has grounded against the dryer body. Instead of the power going through the control system and shutting off the heater, the power is going through the broken part of the heater and then to the dryer body with no shut off point like a direct circuit. Probably needs heater replaced. Could also be one of the controls stuck but usually the 1st problem I stated..
Mar 28, 2015 | Maytag MED5770TQ Electric Commercial Dryer
Cooling light stays on during dry cycle. no heat is to dry clothes. I've switched the circut breaker numerous times and unplugged the unit many times also to "reset" . What's next..
Try a timed dry cycle instead of an automatic cycle. If that works, then you will need to clean off the moisture detection bars inside the dryer to get the auto cycle to work again. Look for two curved metal bars, about 3/16 inch wide and 4 inches long, about an inch apart, located just inside the front of the dryer, near the right side of the lint filter. (you'll have to stick your head in the dryer drum to see them) Often times, use of dryer sheets will result in a waxy coating forming on these bars, preventing the dryer from detecting the moisture in the clothes. The dryer sees no moisture, it goes into the cool down mode and then stops. Clean the bars off, and you should be back in the laundry business.
Feb 05, 2011 | LG DLE7177 Dryer
Roper RGX5634KQ2 Dryer will fire initially, and heat up. It will stay fired up for around 1-2 minutes, and go out. After another couple minutes, the igniter fires, but there is no flame. This continues...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Could be a coil...but I have learned that it usually is the ignitor...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Roper RGX4634KQ Gas Dryer
Roper brand electric dryer will not stay hot
Sounds like it may be short cycling on the Hi Limit instead of the operating thermostat. Only way to be sure is to measure the temp inside the drum while operating with a load. Another way is to measure the voltage across the Hi Limit and it should always be zero. Lots of juice (240VAC) back there and safety is paramount.
Eric
Jun 08, 2009 | Roper REX4634KQ Electric Dryer
Hello my Kenmore Dryer is working fine although taking alot longer to dry the clothes. I took everything apart and clean it, no vent blockage, and great air circulation through dryer. I was wondering; is...
THE ELEMENT CYCLES. NO IT DOESN'T STAY ON THE WHOLE TIME, BUT IT SHOULD BE ON FOR MORE THAN A BRIEF SECONDS TOO. POST ME THE MODEL NUMBER FOUND SOMWHERE AROUND THE DOOR AND I'LL HELP FURTHER. THERE ARE THERMOSTAT/S HIGH-LIMIT SHUT OFF SWITCHES AND IF THEY ARE NOT FUNCTIONING PROPERLY IT WILL CAUSE DRYING TIME PROBLEMS
Apr 11, 2009 | Dryers
Hi, thanks in advance for your insight and experience. We have a 4 yr old estate dryer that we love. Recently, it just doesn't get the clothes dry without running it for about an hour and a half. We have...
the element cycles at high temp of around 155 and when it drops to around 85 it comes back on ,,, if it takes as mach as twice the time to dry it has to be in some of the venting ,,,, eather the hose behind the dryer was or is kinked or the venting going outside is part way stopped up / larry
Nov 28, 2008 | Dryers
Estate TEDX640JQ Electric Dryer Logo
55 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
