Question about Brother Sewing Machines
My PE 100 keeps breaking needles, they are striking something during use.
  • 268 Answers
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric.
    * When you insert your new needle, make sure it’s positioned correctly (usually with the flat side
    away from the bobbin, but consult your manual), that it goes all the way into the holder, and
    that the screw is securely tightened.
    If this doesn’t seem to be the problem
    * Check your pressure foot
    Make sure it’s attached securely.
    * Change your pressure foot
    Your pressure foot may be bent, causing your needle to hit it.
    * Don’t sew over pins
    A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
    * Don’t pull your fabric as you sew
    You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
    * Check your needle plate
    Make sure it's securely in position.
    * Change your needle plate
    If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for
    sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
    * Check the position of your needle
    Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
    I hope this helps.
Posted on Sep 15, 2009
  • sjk7430 Aug 07, 2011
    Needle keeps hitting plate and breaking.
My pe 770 brother machine. Why is it that the thread breaks all the time I want to use it
Usually misthreading, however, it could also be something else, ie needle, old or bargain bin thread, tension, burr or snag.
Why is my thread breaking
Apr 05, 2018 | Brother Sewing Machines
The upper thread keeps breaking whenever I sew even though it is always properly threaded and the needle is fine
check the age of the cotton
cotton is not a single thread but a series of fine threads bonded with a glue
old cotton glue breaks down and the thread separates easilty
next check that the needle is installed correctly with the grove ( thread groove away from the bobbin hook
check the needle and hook timing because if it is off a fraction , the hook will pierce the the thread causing it to break
next check that the eye is the correct size for the thread in use
a needle eye too small for the thread thickness will jam the thread ans not let slide through the eye properly
Nov 25, 2017 | Sewing Machines
My sapphire 835 keeps breaking needles and the thread keep balling up. The needle keeps hitting the back part of the snap on foot.
It's probably time to take your machine for service and get the adjustments done that it needs. If it is not already out of time, it will be soon with all the needle striking that is occurring.
May 01, 2017 | Sewing Machines
How do I adjust my Thompson mini-walking foot machine?
It may be your timing got knocked out of whack. Go on youtube.com and look up how to time a sewing machine with Niler Taylor. She is a great teacher. It may save you $100.
Jan 24, 2018 | Sewing Machines
Needle keeps breaking HELP!
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
I suggest contact brother.com or a dealer about the needles , cause
I've checked on the internet and on the brother site about the needles and couldn't find any information.
Jul 26, 2012 | Brother PE-150V Computerized Sewing...
My needle keeps breaking
Needle breaks
Jun 18, 2012 | Brother PE-150V Computerized Sewing...
Husqvarna Viking Designer I breaking needles
Make sure that the metal plate is locked into position- Hope that helps!
Jan 20, 2010 | Husqvarna Designer I
Thread keeps breaking
With the foot in the down position, can you pull thread through without any hangups? And I'm assuming it's the top thread you're speaking of. The other obvious thing to look for is any burrs or deformations on the hook. Any needle strikes or other rough spots will cause thread to break quickly. Also look at the needle plate for rough spots.
Feb 20, 2009 | PfaFF Quilt & Craft Pro 7530
Sewing Machines Logo
272 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
