1999 Buick Regal Logo
Posted on Sep 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intake manifold gasket / replace
Guide to replace intake gasket on 1998 olds bravaca
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on Sep 16, 2009
Anonymous
Expert
Level 2:
Answers
65
Questions
0
Helped
36918
Points
198
3.8L Engine
NOTE The 3.8L (VIN K) non-supercharged engine uses a two-piece intake manifold consisting of an upper air plenum which mounts the throttle body and a lower intake manifold assembly which houses the fuel injectors. The 3.8L (VIN 1) supercharged engine uses a similar lower intake manifold. The supercharger serves as the upper manifold.
Lower Manifold
NOTE Two bolts which fasten the lower intake manifold to the cylinder head are accessible only after the upper intake manifold is removed. These bolts are located in the right front and left rear corners of the lower intake manifold. Remove the upper intake manifold to service the lower intake.
The 3.8L (VIN 1) supercharged engine uses a manifold similar to the 3.8L (VIN K), but the supercharger serves as the upper manifold.
  1. Disconnect the negative battery cable.
  2. On 3.8L (VIN 1) engines, remove the supercharger assembly. Please see the procedure in this section.
  3. Remove the upper intake manifold using the procedure above.
  4. Remove the EGR outlet pipe from the intake manifold.
  5. Detach the engine coolant temperature sensor wiring harness from the sensor.
  6. Remove the lower intake manifold bolts and carefully lift off the manifold.
To install:
intake manifold gasket / replace - 0900c15280269f1b.jpg enlarge_icon.gif Fig. Lower intake manifold bolt torque sequence-3.8L (VIN K) engine
  1. Clean all parts well with degreaser, especially the gasket seal surfaces on the upper and lower manifold pieces and between the lower manifold and the cylinder heads..
  2. Install new gaskets to the cylinder heads and new seals to the engine block. Carefully lower the manifold into place. Apply thread-locking compound to the bolt threads. Make sure to install the two hidden bolts in the lower intake manifold. Hand start all bolts, then torque evenly to 11 ft. lbs. (15 Nm). Follow the toque sequence, starting in the center, then working outwards in a circle.
  3. Install the remaining components in the reverse order of the removal process.
Upper Intake Manifold (Plenum)
  3. Tag for identification, then remove the right side spark plug wires.
  4. Disconnect the ignition wires from the fuel rail.
  5. Remove the fuel rail. Please see Section 5.
  6. Remove the cable bracket from the intake manifold.
  7. Remove the throttle body.
NOTE Two bolts which fasten the lower intake manifold to the cylinder head are accessible are accessible only after the upper intake manifold is removed. These bolts are located in the right front and left rear corners of the lower intake manifold.
  1. Remove the upper intake manifold bolts and carefully lift the upper intake manifold from the engintake manifold gasket / replace - 0900c15280269f1c.jpg/ol>
    0900c15280269f1c.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Upper intake manifold and bolt torque sequence-3.8L (VIN K) engine
    To install:
    1. Clean all parts well with degreaser, especially the gasket seal surfaces on the upper and lower manifold pieces.
    2. Install new gaskets to the cylinder heads and new seals to the engine block. Carefully lower the manifold into place. Make sure to install the two hidden bolts in the lower intake manifold. Hand start all bolts, then torque evenly to 89 inch lbs. (10 Nm). Follow the torque sequence, starting in the center, then working outwards in a circle.
dennis nelson
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 11, 2023
dennis nelson
Contributor
Level 1:
Answers
Questions
Helped
3158
Points
My identifix is down. Need labor hours for intake manifold gaskets on 1998 Mark VIII 4.6
No small task. A lot to get out of the way and replace to access intake and gaskets. Expert with proper tools 4-6 hours
1helpful
I need to replace the knocking sensor on my 1998 nissan pathfinder. Can you please guide me?
to replace a knock sensor on a 1998 pathfinder is a big job.
you have to take out the whole intake manifold, so you can reach the sensor.
if you want to do it by yourself \, first you should have ready all the tools and parts.: including a torque wrench and a set of intake manifold gaskets. you can try here autopartsway.ca for some good cheap parts.
and be ready to work few hours if you do not have much experience as a automotive mechanic.
so, good luck, if you did not do it already.
1helpful
Head gasket
These cars do not have head gasket problems you need to remove the sparkplugs to get the coolant out and replace the black upper intake manifold as they will leak coolant into the combustion chamber. Common problem.
2answers
It leaks coolant under the thermostat houseing between the block and manifold
Sounds like your intake manifold gasket is leaking. This is a very common problem for these trucks.
2answers
Need a diagram of water coolant including freeze plugs . I am leaking antifreeze and have replaced pump, therm already. It seems to be coming around the timing cover
timing cover?? take it off again and check the pump.Did you clean the old gasket off properly??was it a new pump in a box?? could pump be faulty manufacture
10helpful
2answers
HOW TO REPLACE INTAKE MANIFOLD ON A LINCOLN
answer , very carefully ...
drain coolant , remove and mark all vacuum lines , make a schematic to diagram your hose routing, disconnect and plug all fuel lines, remove distributor and mark location of rotor, disconnect battery, remove any necessary cables, brackets and or accesseries, remove intake mounting bolts, note length of bolts and reference location, pry up on intake , remove intake, scrape old gasket off , must be very clean to reinstall new gasket or you will cause a leak..
How many intake manifolds does a 1998 buick park avenue have? Also is this a difficult job to do? I have heard these cars are notorious for melting there intake manifolds, is there a metal replacment of...
2 upper pellum and lower intake gasket( both are called intake gaskets) I did it. time consuming alittle but if your ave or above with mechanics then you'll save yourself $2000.. the new pelunum and gasket cost $130 and it comes with improved gasket and a replacement pipe the melts also. lower gasket $40? need more help or info email me! Richie
Blown upper air intake manifold on gm 3800 series two engine
Parts stores carry a kit including a manifold and gaskets. When I do the job I always replace the lower intake gaskets because they leak too. Make sure the lower manifold is not warped around the rubber gaskets towards the throttle body side, a new or used loewr manifold might be needed to ensure a correct repair.
Removing starter from toyota corolla 1998
No. Removal of the intake manifold is not an attractive option.
...That will cost you more time and money in the long run.
You will need to replace the intake manifold gasket, and several others.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
