Question about Patton Electric U2-20 Box Fan
My fan makes a lot of noise when running a kid of knocking noise like it is breaking down. It is most noticeable at slowest speed. Any ideas?
  • 60 Answers
Unplug fan remove cover and see if the fan has a nut or wingnut at the front and make sure it is tight. If all appears to be well then it might be a bearing and that would make it hard to replace. If you grab the blade and wiggle it and it is loose check to see all forms of fasteners are tight. Failing that check with manufactureer for an autorized repair depot to get the bearing replaced if it is worth doing.
Cheers
Al
Posted on Sep 11, 2009
Frigidaire FFTR1619RS1 makes knocking noises while running. Is this normal? See videos inside.
I would suspect it is a loose blade on the condenser fan or else something caught on the fan to make it off balance. Pop the back cover off and take a look. Once, I had a fridge that sucked up a plastic bag.
Nov 18, 2016 | Frigidaire Refrigerators
KSM90 Mixer knocking sound
The armature will not normally make a knocking noise, even on low speed it is turning at hundreds of revolutions per minute so you will only get a whirr not a knock. Most common knocking is the plastic fuse gear missing a tooth or two. That is the first gear driven directly from the end of the armature. What you should have done is break it down slowly while always keeping it together enough to run it with one component less each time. Remove planetary.....run it. Split gear case apart....run it. That sort of process will give you a clue where you need to be looking for the fault.
Feb 03, 2014 | KitchenAid Food Mixers
2002 mazda mpv air conditioner fan control module problem?
Check and replace fan switch control module located in glove box...$30. part. Do it yourself.
Oct 20, 2017 | 2002 Mazda MPV
1993 subaru loyale is making a horrible knocking/clunking noise
Hi the only other thing it could really be is the wheel bearing itself, usually in subarus they grind or clunk with wheel movement so if you go faster so does the noise, a garage would be able to tell you strait away as you cant really pull them apart without the right gear. Also check the strut, very unlikely but if a spring is collapesd it wll make a similar noise but wont speed up etc, its also worth noting that a cv can make the noises you describe but it would have to be completly destroyed and quite noticable hope this helps
Apr 10, 2012 | 1993 Subaru Loyale
KA 600 is making a clinking noise when mixing.
Tll,
It sounds like it could be an issue with the gear, the motor housing could have a crack in it. The problem could be much more involved as well. Put the unit on the slowest speed and see if you can stop the mixer from spinning. If it hiccups or stutters, that means you have a stripped gear. If you cannot stop the unit using your hand ON THE SLOWEST speed then there could be a problem with the motor housing or the motor itself not being held in place properly.
Apr 02, 2012 | KitchenAid ProLine 600 Stand Mixer
My pc's Front fan is giving bad sound and its speed increases while playing game and give sound but at normal using like chating playing songs it works oK now what to do any one plzz
When you are playing a game, your CPU has to work a lot and a lot of heat is released. To cool it down, the fans run at a high speed making that bad sound. Playing a song does not require a lot of CPU work. To reduce this get a additional fan which can control heat without making noise. Make sure your CPU and the Heat sinkers present are free of dust.
Dec 28, 2010 | Dell OptiPlex GX620 PC Desktop
I have a 2005 Jeep Wrangler Unlimited Rubicon - chirping noise
have a local repair facility look at the front and rear universal joints
Mar 09, 2010 | 2005 Jeep Wrangler
ENGINE KNOCK NOT SURE WHAT IT IS. ENGINE IS IDILING GREAT BUT MOTOR HAS A KNOCKING TO IT AND INCREASES AS MOTOR IS RACED. WHAT SHOULD I LOOK FOR?
engine oil level?? if its correct then look for another engine ,but before you do get a mechanic to have a listen first ,might just be a valve lifter ,or the flex plate on the torque converter broke ,really need to hear it to tell you what it is
Dec 10, 2009 | 1995 Lexus GS 300
Patton Electric U2-20 Box Fan Logo
301 people viewed this question
Top Patton Electric Dryers Experts
Darrell
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Patton Electric Dryer Expert? Answer questions, earn points and help others
