Question about Whirlpool GEW9250P Electric Dryer
When you press the on button there is no light
I have a dryer that's only 4 yrs old all of a sudden when I press on the power button there is no light on the dryer to power up but if you open the door there is light, so there is power, what could be the problem?
  • 30 Answers
There are repair instructions available to show how to replace the thermal fuse for your problem at:
www.AnyoneCanFixIt.com/household.htm
or just go to www.AnyoneCanFixIt.com
Posted on Sep 23, 2009
    President:
  • 1,776 Answers
This sounds like a blown thermal fuse. It's about an inch long and is inside the rear of the dryer and is usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 11, 2009
My dryer will not start. It is only 4 yrs old.
Check your power source to make sure you are getting the proper voltage. If so check the electrical power connection on the back of the dryer where the cord is connected. Make sure the connections are tight. MAKE SURE TO DISCONNECT THE POWER FIRST. If all of the above are in good condition the the start button would be the next area to check whithout the proper electrical meters this would be hard. however, the next item in line to prevent the dryer from working would be the start button or the door closer switch. Both of these need to be checked using an electrical meter. If you have an apliance tech check it for you it shouldn't be expensive at least you hav an idea as to what is wrong.
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
Kitchen Aid Little Ultra Power, 4 yrs old, suddenly stopped.
I HAVE A BASE UNIT WITH NO MIXING BOWL,
HARDLY USED , CAN PURCHASE CHEAP
RESPOND TO garyhp@cox.net
Jul 13, 2009 | KitchenAid KFP450 Ultra Power 7 Cups Food...
Does the Admiral Capacity plus have a reset button anywhere on it. My dryer suddenly stopped only a 4-5 yrs old, great condition. The inside light as well has gone out. It was all ar once no warning
the dryer has a main fuse under the top on the back wall,if that is blown nothing will work,also check the breaker box it might of tripped,-mike
Jun 28, 2009 | Dryers
My dryer suddenly quit working, was working just find.
i would check the door switch behind the dryer door and the main fuse behind the back panel,you can also use a piece wire wire to jump the start switch to check that -mike
Jun 28, 2009 | KitchenAid KEYS750LQ Electric Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Whirlpool GEW9250P Electric Dryer Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
