Question about Yamaha RX-V995 Receiver
Won't power up
I have old Yamaha RXV 995, when power up the receiver, it imediately shut down, what cause the problem.
  • palabras2 Jan 28, 2008
    My problem is the exact same. It started off small with shutting itself off, now it just shuts down when I try to turn on.
    I'm going to see how much to get this fixed, if too pricey, I'll replace the unit. I've loved this through my disasterous marriage to now and it seems if this isn't an easy fix, its gonna go!
    Problem Solver:
Its a consideration....I will let you know.
Posted on Mar 07, 2008
Gentlemen,
It isprobably caused by a corrosion on the plug. When your amp doesn't get enough juice from the mains it senses it and trips.
Try cleaning it with contact cleaners or just sand it a little with any sand paper. Hope it works as well with you as it did with mine.
Posted on Mar 08, 2010
  • 4 Answers
Before u dump the unit i might be willing to buy a peace of it to fix mine if ur interested let me know. facuckoff@hotmail.com
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
Rxv-571 wont power on, no click sound either
Good for you. You are a real techie.
Jul 04, 2014 | Yamaha RXV571
Hi i want to restore factory settings my rxv 995
(input mode key)+ ((AM/FM key) lastly Press (power key)
When diag menu appears select 8
when sub menu appears select RESERVED
use tuning up/down at MAIN MENU and
program up/down to move for SUBMENU
Sep 13, 2013 | Yamaha RX-V995 Receiver
My yamaha rxv 1700 7.1 ch amplifier with defenite speakers shuts of at 40% of volume it gives a the option check the wiring how to solve this problem
Open the unit and inspect for cold solder connections. Use a non-conductive tool to poke the circuit board for the bad connection. Please keep in mind that when you do this, the unit has to be powered up - be cautious of the live circuit.
Dec 29, 2010 | Yamaha RX-V1700 Receiver
When I push the stand-by/on button - stand-by blinking
WHEN I PUSH THE STAND BY BUTTON THE UNIT GETS ON AND IMMEDEYETLY GETS OFF(YAMAHA RXV-995 IF IUSE 500VA STABULISER THAT PROBLEM NOT COMING PLEASE SOLVE IT
Sep 10, 2009 | Onkyo TX-SV373 Receiver
Rxv-520
Hello, it is worth checking that there is adequate ventillation around the unit, especially if it is in a cabinet. Also check that there is no dust clogging the vents on the unit. Another cause for overheating is using speakers that require far more power than your receiver can provide, or speakers with an ohm rating that is lower than the amplifier provides. Also, check to see if any wires to the speakers are crossing over as shorting will cause the amplifier to overheat and cut out. Hope this helps.
Jul 26, 2009 | Yamaha RX-V520
RXV 995 SUB output is DEAD
If there is a real failure in the Sub Output it would indeed be unusual. I'd still sift carefully through all of the settings. The Sub Out is very likely to be its own unique channel so I would try something that bypasses multichannel decoding entirely, like plug in something low-bass-rich to the Subwoofer (IN) at the External Decoder area on the left rear of the unit. Press Ext. Decoder and see what comes out of the Sub output. This bypasses all DSP and could prove if the Sub Out really does work.
Does it not work in speaker level setup either? That at least would eliminate any source issues.
Apr 14, 2009 | Yamaha RX-V995 Receiver
Need to connect tv, satelite and dvd to yamaha rxv1700 receiver
hello i think the question is how to connect two equipment (dvd and directv) your tv has video 1 video2 aux, put one at any input and the sounds out from tv go to receiver inputs,this way you listen what is on tv in your amplifier....................saludos
Nov 24, 2008 | Yamaha RX-V659 Receiver
Yamaha rxv 595 receiver shuts down when volume is increased
THE SPEAKER WIRES ARE REVERSED.... On the receiver the red side is always positive and black is always negative.
change + to - or
change - to + on one or more speakers.
positive side--------------------negative side
red --------------------------------black wire
gold wirew/silver--------------silver wirew/gold
white lined----------------------non-white lined
Oct 30, 2008 | Yamaha HTR-5730 Receiver
Yamaha rxv-992 receiver wont power up
Disconnect all your speakers from the receiver. Turn the power on, and see if it stays on. If the unit shuts off with all the speakers disconnected, then you most likely have a faulty unit, and it will need to be repaired or replaced.
If the unit stays on with all the speakers disconnected, then you most likely have a bad speaker or a bad connection with the speaker wire.
Starting with one speaker, hook it up, and turn the unit on, and again see if the unit stays on, or if it shuts off. Do this until the unit shuts off when you connect a speaker.
Then disconnect all the other speakers, and leave the suspect speaker attached. Again, try to power up the unit. If it fails with that speaker attached, but works when it is not attached, then that speaker is your problem.
Sep 02, 2008 | Audio Players & Recorders
Yamaha RX-V995 Receiver Logo
341 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
