Question about Symbol MC9090 Barcode Scanner
Will not scan
I cannot get DataWedge to load properly. During start up I get an error message "Failure during read attempt" A0000023? When I pull the trigger no red beam of light.
    New Friend:
  • 65 Answers
This is mostlikely a hardware failure but re-flashing to factory defaults would be a strong suggestion. Please contact me for detailes on the process. You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Posted on Oct 20, 2009
6 beeps what dose it means
Dell beep codes:
If your computer beeps during start-up:
Run Dell Diagnostics to identify a more serious cause.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Contact Dell for technical assistance.
Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM read/write failure 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer failure 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3 Video Memory test failure 1-3-1 through 2-4-4 Memory not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller test failure 3-3-1 NVRAM power loss 3-3-2 Invalid NVRAM configuration 3-3-4 Video Memory test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No timer tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math-coprocessor test failure 4-4-4 Cache test failure
Aug 12, 2013 | Dell Gx620 Gx 620 Sff P4 Ht 2.8ghz 1gb...
Pls, how can i solve an error problem on laptop that says '1308.source file is missing' while i'm doing some installations
This behavior occurs because some files are not read properly from the DVD-ROM during the file copy phase of the setup process; some files may become corrupted.
During some occurrences, you may receive an error message. During other occurrences, you do not receive an error message and the file is copied without errors; however, a piece of the file is corrupted after the file is copied to your computer.
Firmware updates should resolve this issue:
hope this helps
Nov 28, 2011 | HP Computers & Internet
My dell inspiron 6000 wont boot up. error message Windows\system32\config\system is missing or corrupt
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Oct 26, 2010 | Dell Inspiron 6000 Notebook
Hi all , My HP laptop auto shuts down when i open microsoft words , why is this so ? can somebody pls help me ? I need todo some work on it urgently!! , Thanks !!
You will need to press the F8 key before windows starts to load then disable
the auto restart on error. That will allow you to read the error message and
someone may be able to guide you.
You could also try booting from the XP CD and run the recovery console (if
that's an option) once in the recovery console type chkdsk /r to correct any
errors & try booting again.
OR
Disable automatic restart on system failure. This should help by
allowing time to write down the STOP code properly. Right click on
the My Computer icon on the Desktop and select Properties, Advanced,
Start-Up and Recovery, System Failure and uncheck box before
Automatically Restart.
Do not re-enable automatic restart on system failure until you have
resolved the problem. Check for variants of the Stop Error message.
An alternative is to keep pressing the F8 key during Start-Up and select
option - Disable automatic restart on system failure.
If you are using a wireless keyboard and the F8 key does not work
substitute a wired keyboard and mouse for this exercise only.
Please prost your feedback.
May 19, 2010 | Computers & Internet
I have an acer aspire 3620. during boot-up, windows begins to run and then an error message reads: "PXE-E61 media test failure, check cable" appears. it gives me the options of starting windows regularly,...
Do you have a disk or built in recovery. either way it sounds like you need to put a fresh set of windows on your system. Please let me know what happens and i will help all ican Robert
Apr 05, 2010 | Acer Aspire 3100-1405 Notebook
Having error messages during canning, error
I think you did scanning directly from your printer, you should scan from the computer, just go to my computer and look for your scanner. Then you can scan whatever you wanted to.
Sep 29, 2009 | HP Deskjet F4100 All-In-One InkJet Printer
Fatal error message 13DOH
Per service manual, Parameter Chip failure
Data, which has been written, is read, checked, and
found faulty; rewriting of the data is then executed and
the data is checked to be found faulty during re-reading.
• A count value is found faulty during reading.
• Parameter Chip is detected to be not mounted during
initial mounting detecting sequence.
Did you recently have the firware updated? Or the main board has crashed. have service Technician reflash the software, or down load it.
Jul 31, 2009 | Konica Minolta Office Equipment & Supplies
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Im getting an error code 08-0E89-0000 how do i fix this I had Toshiba A305-6844 after removing all the partition from the HDD using Recovery Disk I get Error #08-0E89-0000 while recreating the partitions...
I had the same message, replaced the hard drive, still got the same error code, took the hard drive back to best buy and they game me a new one, put it in and got the same message again...
Jul 02, 2008 | Computers & Internet
Problem with barcode scanner
Interleaved 2of5 symbologies is normally disabled from factory. what scanning software are you using? have you tried Datawedge to enable the scanner? Is a free download from symbol/motorola and it goes very well.
Mar 05, 2008 | Symbol MC3090
Symbol MC9090 Barcode Scanner Logo
1,432 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
