Question about Fujitsu fi-4530C Pass-Through Scanner
Our fujitsu scanner has something inside it that is putting a dark line that skips about an inch from that right margin. It does not put it on all the pages that get scanned in. Every so many pages. We have cleaned and cleaned the inside glass. it is gone for a few pages, and then it comes back and gone again.
  • Jarratt May 11, 2010
    is this on the front image or the rear image? have you checked the glass for any scratches that may get dirt in it, producing your line? how wide is the line? as wide as a pen line or wider?
    President:
  • 3,085 Answers
The LED's in the scanner assembly are not coming on every time you scan. It needs to be replaced.
Posted on Sep 19, 2009
Copy/scaining problem
because there may be no page (or no page detected) in those 2 dark inches.
Feb 17, 2014 | Samsung CLX 3305 - multifunction fax /...
I m completing six months looking for an SDK for APC Biopod Fingerprint Reader. The device isdoing well for logging into my windows XP OS. The challenge now is i want to incoorporate the device to my...
We bought Fujitsu 5650c scanner trying to use twain driver to scan, all the time image is moving to the right side. Meaning a huge 2 inch gap is appearing on teh left margin, the content getting chopped. No matter if we increase the width and height of teh image also still the left side gap is appearing. and with other scanners the twain based program is working fine. we have downloaded and installed latest drivers from fujitsu site, tried from various machines various Os still the problem remains same. Any one observed this issue before? and this scanner can only be connected via USB no network option to use ethernet cable very frustrating. Raj
Jul 12, 2013 | Office Equipment & Supplies
Black line coming out on prints
Yes, you have a defective cartridge.
Apr 15, 2010 | HP LaserJet 2550n Printer
Fujitsu fi5650 hispeed duplex scanner
Check the following items:
1 Does the document satisfy the paper specification?
2 Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
3 Replace the Pick roller and the Brake roller and see if the error is resolved. Check the consumable counter in the software operation panel or in the built-in Maintenance mode. When the counter exceeds the values, replace the Pick roller or the Brake roller.
4 Are the cables between the Control PCA and the Feed motor damaged? Are the connectors connected properly?
5 Is the Optical unit ADF installed correctly?
6 Is the Belt ADF installed correctly?
7 Is the Belt ADF damaged?
8 Replace Feed motor and see if the error is resolved.
9 Replace the Optical unit ADF and see if the error is resolved.
10 Replace the ADF unit and see if the error is resolved.
Pls acknowledge of the issue is resolved.
Regards,
Tech Satya
Aug 06, 2009 | Fujitsu fi-5650C
Lexmark T614 horizontal lines on right the left margins
This sounds like a cartridge problem if you have changed the cartridge and the problem persists I would say it is the positive charge roller inside the printer. If you open the cartridge door and remove the cartridge with the cartridge out starting closing the door and you will see this roller moving down from the top inside of the printer. do not touch this without a glove or lint free cloth. not hard job to change if you can get one in your area if not we have them available.
laserguy@nbnet,nb,ca
Feb 05, 2009 | Lexmark Optra T614 Laser Printer
A Dark Vertical line appears 1 inch into the left side of scan
Most Mustek scanners have a black inside cover on the lid, this can give a black line down the side of the job.
ether cover the inside of the lid with white paper or place a bigger sheet on top of the sheet to be scanned!
Jan 24, 2009 | Mustek A3 USB Flatbed Scanner
Black line inide right margin of anything with a graphic element
Hello ,
Before printing from application > go to properties > under type, select Rough or heavy and then print it
- NIkhil
Nov 15, 2008 | HP LaserJet 1020 Printer
Black line down right margin
Have you tried a new toner and drum unit? if not please do so. If that doesn't work then it is a scanner lamp failure and will need replacing.
You can fix it but trying to obtain this part for such an old machine will be hard. Don't know the part number sorry.
Thanks J
Jan 30, 2008 | Brother MFC 8500 All-In-One Laser Printer
Black vertical line
There is a User Shading Utility on the original product CD. Browse to the CD drive and open the folder named ShadingUtility. Run the program ShadingUtility.exe the password is GOSHADING (all caps, no spaces). Put a clean, white sheet of paper in the scanner (or glossy photo paper works really well), then click the Shading button.
Dec 13, 2007 | Panasonic KV S2026C Path-Through Scanner
Fujitsu fi-4530C Pass-Through Scanner Logo
143 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
