Question about Dryers
Whirlpool Gas Dryer LGL8858000 (1995? Manufacture?)
This particular model has an easy clean 100TM lint feature collector basket on top of the dryer. Lint usually collects in this box. However, it is not collecting anything. Page 12 of the User Handbook for this product says to call Consumer Assistance Center which I have done. They cannot help me. They want me to get a repairman. I would like to try to solve the problem myself before I pay $75 for a repair person to come into my house. The dryer works fine except for this problem.
night71
  • 328 Answers
SOURCE: Whirlpool Clean Touch Model LGL88580000
You can check for suction by pulling out the lint screen and holding a piece of paper over it while the dryer is running. If there is suction then it all works correctly. If there is no suction, then there is a clog somewhere inside. You can clear the clog with a long bottle brush or with an attachment from a vacuum cleaner to get inside. If all looks good and still no lint on the screen, the screen may be too short for the dryer and could be a wrong screen for it.
Posted on Dec 18, 2007
SOURCE: water dripping outside the collector
I think that there is a 90 degree bend in the outlet on the bottom right front side of the collection tray that gets pluged with dirt, line etc. You can see this when you remove the collection container from the unit. I used a small piece of wire to clean out the hole and now the water goes into the tank and not onto the floor.
Posted on Sep 15, 2008
SOURCE: Panasonic SR-SH15PS
http://www.forumappliances.com
Posted on Nov 02, 2008
  • 423 Answers
SOURCE: how do you clean out food debris collected at the back?
I was not able to find any specific information about the Moffat MSC3504 dishwasher. I recommend you go to this site and download the only manual that I could find for a Moffat. It may have some hints for you.
Also, if you see screws holding the mesh down, recommend you take a picture of the area and have at it!
http://www.usersmanualguide.com/moffat/dishwasher/mdw542
Please be generous when you rate my level of helpfulness as I am in the US and have never touched a Moffat model.
Posted on Apr 01, 2009
  • 148 Answers
SOURCE: Coils freeze, no water in collector. Model AD7ousso
needs to be charged with freon
Posted on Jun 21, 2009
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
May 07, 2014 | Whirlpool Dryers
Dec 18, 2007 | Whirlpool LGQ9858P Gas Dryer
My whirlpool ultracare !! dryer will not heat. I have to dry things over and oer and over til they finally dry.
i looked up your model number and that's to a washer not a dryer.if it's a gas dryer it sounds like you have bad gas coils located on top of the gas valve.the coils work until they heat up like in the first 15 to 30 minutes and they shut down,when they cool they work again until they heat up and fail,this is why you have to keep running thedryer,one more problem could be the dryer needs to be cleaned out.clean out the vent line,clean out the duct that the lint filter slides into and vac out the cabinet where the motor is
Jan 22, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Fisher paykel smartload dryer degxius does not dry cloths. Drum is hot, and lint basket is empty. I have cleaned lint out behind lint basket.
Check and make sure that your exhaust tube and outside vent are not clogged. If they are clean them out and you may have to buy and new lint screen that come with a seal whcih will solve your problem. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum will further help you through your problem.
Sep 04, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer cuts off after 10 minutes
Agree with you. Make sure the lint collector is clean and ditto for the vent. If it goes up to roof have to check it there also to make sure there are no obstructions whatsoever in vent line. Unit is turning off because it is overheating. If lint collector and vent is squeaky clean and unit blows out like crazy then the temp switch is opening up prematurely and might need replacement or jumping - your call. If you want to check for part go here Search Over 2 1 Million Appliance Parts
Sep 06, 2017 | Whirlpool LER4634J Electric Dryer
Gas dryer quit heating
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
The dryer ignites but the gas valve does'nt light
Check that the gas sensor is clear or any lint/dust/crud, etc. as that could be preventing the gas valve from opening up and allowing ignition. Typically all gas dryers have a safety feature that won't allow operation if the exhaust vent pipe has excessive lint and dust in it, as that is a fire hazard.
Look in your owner's manual to see the procedures for accessing the vent exhaust and follow your specific instructions. Usally there is an access panel/door at the bottom front of the dryer that will allow you to get inside the vent, etc. Inside that is a surface mounted sensor that does a couple of things; checks for proper air (venting) flow; no excessive dust/lint buildup; and that the ignitor coil has been "lit", etc.
If any of these doesn't occur, the gas valve will not open. Follow the monthly cleaning procedure/check to make certain that the dryer is safe to use and operate.
If all the above are OK, then it is likely that the sensor has failed and needs to be replaced. You can look at the searspartsdirect.com to find your particular model using their parts diagrams and illustrations of your dryer, etc.
Glad to assist!
Jul 13, 2009 | Amana NGD7200TW Gas Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Gas Dryer - takes to long to dry
Friend,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.If the vent line is kinked or blocked
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
Take the vent line off the rear of the dryer and try if it works. If it does you know it's the vent line and not the dryer that's the problem the dryer.
You will be fine
Bless You huuum
Feb 01, 2009 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
BE SURE TO UNPLUG BEFORE WORKING ON IT.
May 17, 2008 | Whirlpool GEQ9800P Electric Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
