Question about Canon PIXMA MX310 All-In-One Printer
Paper jams-- feeds two or three sheets at a time, need to restack paper in tray
I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
If you do not have a manual it can be downloaded from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
Issue: More than one sheet of paper feeds while printing
Solution: Clean the paper feed rollers using the MX300 operator panel
sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
2. Clean the paper feed roller.
(1) Press the Menu button repeatedly until MAINTENANCE appears.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
The paper feed roller will rotate as it is cleaned.
3. Repeat step 2 twice.
4. Open the Paper Output Tray.
(1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
(2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
Set the Paper Thickness Lever to the left.
6. Repeat step 2 three times.
The paper cleans the paper feed roller as it feeds through the machine.
If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
Dec 25, 2010 | Canon MX300 Office All-In-One Printer
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
Im getting an error mp5100, after a paper jam that was removed and the error continues even though I turned the printer off several times
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch
Oct 26, 2010 | Canon Pixma MP480 All-In-One InkJet...
Paper was jammed, it split. We went through back of HP Officejet7310 to remove paper. After we removed it three lights came on and kept coming on without stop constantly. Auto Answer, Exclamation, and...
FLOWO THE STEPS
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 25, 2010 | HP PSC 1610v All-in-One Printer
When trying to print the printer pulls in more than 1 sheet of paper causing a jam in e.ta
just folowe the steps
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 21, 2010 | Epson Aculaser C1100 Printer
It has paper jam some times on the begining of trasfr belt sometimes middel of that and also it send two diffrent error messages 13.01 and 13.09?
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 20, 2010 | HP LaserJet 5550 Printer
How to clear a paper jam you can't see
Dear SIr,
plzz folow this step,
  • Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
  • Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
  • Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
  • Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
  • Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
  • Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
  • Thanks For Your Time
    Apr 10, 2010 | Dell 924 All-in-One InkJet Printer
    Error message says"out of paper" when paper tray is fully loaded
    check and make sure that the paper is in near the rollers enough that it senses the paper and picks it up. try lightly pushing the paper down toward the rollers as it is suppose to pull one sheet through the feeder. hopefully, you didnt pull too hard on getting the 'jammed' paper out that it may have caused a misalignment in the feeder. try assisting the paper, that usually fixes it. hope this helps!
    Aug 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
    Hp psc 1315 paper jam
    . Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
    2.
    Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
    3.
    Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
    4.
    Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
    5.
    Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
    6.
    Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
    7.
    Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
    Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
    Paper feed/jamming problem
    suggest you bring your orinter to the nearest authorised repair center. There might be parts to be replace
    Mar 23, 2008 | Brother HL-2040 Laser Printer
    Canon PIXMA MX310 All-In-One Printer Logo
    old marine
    old marine
