Question about Hitachi 55UX58B 55" Rear Projection Television
Hitachi model 55ux58b
When power button is pushed nothing happens. The manual tells me to take plug out for 30 seconds and put back in. then hit power button again. I've tried this and the red light power button comes on for 1 second then shuts down. the tv has an awsome picture, I sure hope I can fix it.Do you have any idea what the problem could be?
  • f15man Dec 10, 2007
    once
    once
    President:
  • 4,402 Answers
How many times does the light blink?
Posted on Dec 10, 2007
  • Cary Farah
    Cary Farah Dec 11, 2007
    did you look in the back of the set for lights?
    replacing the IC? STK392-110 is a popular fix for these sets
    http://cmpalmer.blogspot.com/2006/11/fix...
It won't come on at all, so I unpluged it, I opened up the back and plugged it back in. two small green lights come on, and 2 seconds later a 3rd light comes on...and then all 3 pop off. the lights are all on the bottom floor of the tv.
Posted on May 17, 2011
  • neighbor1 May 17, 2011
    That's not a solution.... its a problem I have with MINE:)
  • Hitachi Master
  • 3,459 Answers
On this model there is a common failure with some capacitors and fuses. Its a simple fix if you know which parts to use/avoid and how to do the repair. You can get complete instrucitons and parts for your model from www.TvRepairKits.com . Their kits include step by step color instruction guide as well as the correct parts to fix this issue.
Posted on Jan 22, 2011
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
Power button is not working travelmate270
Give us more details? What do you mean Not Working? Are you saying that when you press the Power Button, nothing whatsoever happens?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 06, 2012 | Acer TravelMate 2702WLMi Notebook
Hcl es2 laptop power button track open soultion
What happens when you hit the power button?
Apr 05, 2012 | Computers & Internet
My HP xw4300 does not start?
What happens when you hit the power button to start it?
Apr 02, 2012 | Computers & Internet
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
Mar 31, 2012 | Computers & Internet
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Mar 30, 2012 | Computers & Internet
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
HP Laptop
Try this,
Unplug the laptop, remove the battery from the underside (there should be a catch to push, and the battery will pop out). Then wait a few seconds and put the the power cord back in and the battery. Hold down the on button for a few seconds and boot it up.
May 22, 2008 | Computers & Internet
Tv problems
first i would check for any loose connections on the convergence ICs if not you may want to try to Replaced both convergence ICs (STK392-110)
Mar 23, 2008 | Hitachi 55UX58B 55" Rear Projection...
Televison & Video Logo
231 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
