Question about Starbucks Saeco Italia Digital Barista Coffee Machine
The lttle filter disk and the plastic rod that is attached to it, release and shoot out, ending up the the grounds drawer. Starbucks Barista - Digital Liz
  • 1,089 Answers
Hi
The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have a item about that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that’s the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it’s a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Posted on Sep 11, 2009
I notice I have to empty the grounds drawer more often because there seems to be more water coming into the drawer with the used pucks when they drop. Before I would empty it after about twelve pucks, now...
Hi
There is a small knob in the bean hopper. It sounds like it is all the way to the minus. Turn it back towards the plus(+) then back 1 mark. Then try again. It could also be a stripped thumbscrew that pushes up and allows the coffee to fill the head and dredge drawer. See if there is any water in the top of the brew unit where the thumb screw is? The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. It holds the filter screen in place. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that's the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it's a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Apr 22, 2011 | Starbucks Saeco Italia Digital Barista...
I have a new to me Starbucks Italia. I have made a few shots and it is telling me to "empty grounds". I have done so but the empty grounds mssg won't go off and it won't function. what do I need to do?
Hi
When you want to empty the grounds because it says to in the menu, REMEMBER TO LEAVE THE MACHINE ON when you remove the drawer. The machine is a counter and when it reaches the magic number for that machine the message comes on. If the machine is turned off when you pull the drawer out, the machine doesn't know this and the message will be there when you turn the machine back on. Also remember to leave the drawer out for at least 15 seconds or a little longer so the machine thinks you actually dumped the grounds.
Oct 04, 2010 | Starbucks Saeco Italia Digital Barista...
Will not prime
Try this make sure the end of the wand is clear, then open hot water knob and push in on button if that works, replace the steam tap rod.
Mar 06, 2010 | Starbucks Saeco Italia Digital Barista...
Where to buy Starbucks(Bodum)Barista Utopia coffee maker filters
Good luck as they dont make them anymore, you can maybe get one on EBAy for big bucks, I found one at my thrift store before christmas for $15.00 and almost died, and it is new...awesome!
Mar 17, 2009 | Starbucks Barista Utopia
I am having a problem with my Starbucks Barista Aroma Grande Coffee maker We have had it for 5 years and it has been great but recently almost every time I make coffee and walk away from it, I end up...
The exact same lid is on the Wolfgang Puck WPTPCM010 coffee maker. (It's exactly like the Starbucks one - same size & fit.) Call (800) 275-8273 and order part # WPTPCM010-6; the product description is "LID FOR CARAFE". It will cost you $4.99 + 5.00 shipping. My Starbucks coffee pot works PERFECTLY again. Just make sure that you put the lid on the carafe correctly before you use it, since the seal is new.
Mar 06, 2009 | Starbucks Barista Quattro Coffee Maker
Barista Zia Espresso Machine
file:///Users/Julie/Downloads/Barista_Final_011305.pdf
I had the same problem. The Barista Zia is the same as the Barista Athena on the inside, the only diffrence between the two is the plastic shell on the Zia, and the steaming wand is on the opposite side. This is the instruction manuel for the barista athena, so its basically the same. Thanks! good luck!
Nov 10, 2008 | Starbucks Coffee Makers & Espresso...
Replacement part
http://www.partsguru.com/SaecoRioProfi.html
Item # 144650100T
Aug 30, 2008 | Starbucks Barista Utopia
Need to replace water carafe to Starbucks Barista Araoma 12-Cup Coffee Pot
I have the same problem, but have not been able to find a new carafe, so far.
Jun 10, 2008 | Starbucks Barista Quattro Coffee Maker
Water in the coffee grounds drawer
Look for a leak near the brew group on near the piston area.
Changing the brew group should solve this problem.
http://cerinicoffee.com/item.asp?cID=0&PID=206
Johnny C
www.cerinicoffee.om
Oct 01, 2007 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
94 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
