Question about Franklin Industries FWC35 Compact Wine Cooler Side by Side
NOT COOLING (Franklin FWC35)
The other night the "hi temp" alarm went off. I pulled the front lower vent cover and removed a wall of dust from what looks like some coils??. The fan did come on later but in the morning it was reading the same temp (71 deg) unplugged for a bit and plugged back in and have not heard fan turn on or any noise. The display lights up. I can adjust temp setting but it never cools. When I removed my wine I noticed a demple inside, at the bottom, about 3 inch circle, that the plastic looks to have melted a bit. Can't find a repair manual. Any info at all will help. Thank You
  • 60 Answers
Sound like maybe the Compressor may have packed it in. Sometimes they overheat and that is what melts the plastic liner of the refridgerator. You need to call a service repair person or simply take the small frideg to them at the repair center. Most manufactureres have a repair cneter locator. Go to their web site and find the autorized repair center near you. If it is still under warranty you will in most cases need to find the receipt. ( TIP I put a copy of the receipt on the back in a ziplock bag on all appliances) This makes it easier to find them when things go wrong.
Cheers
Allen
Posted on Sep 11, 2009
Front seal replacement 5.9 cummins
Hi Dale, I'm glad to help! Below is the removal procedure for the front crankshaft seal on your 5.9 cummins engine. Hope this helps and have an awesome day!
REMOVAL
  1. Disconnect both battery negative cables.
  2. Raise vehicle on hoist.
  3. Partially drain engine coolant into container suitable for re-use (Refer to 7 - COOLING - STANDARD PROCEDURE).
  4. Lower vehicle.
  5. Remove radiator upper hose.
  6. Disconnect coolant recovery bottle from radiator filler neck and lift bottle off of fan shroud.
  7. Disconnect windshield washer pump supply hose and electrical connections and lift washer bottle off of fan shroud.
  8. Remove viscous fan/drive assembly. (Refer to 7 - COOLING/ENGINE/RADIATOR FAN - REMOVAL).
  9. Remove cooling fan shroud and fan assembly from the vehicle.
  10. Remove the accessory drive belt (Refer to 7 - COOLING/ACCESSORY DRIVE/DRIVE BELTS - REMOVAL).
  11. Remove the cooling fan support/hub from the front of the engine.
  12. Raise the vehicle on hoist.
  13. Remove the crankshaft damper and speed indicator ring.
  14. Remove power steering pump.
  15. Remove accessory drive belt tensioner.
  16. Remove the gear cover-to-housing bolts and gently pry the cover away from the housing, taking care not to mar the gasket surfaces. Remove crank seal dust shield with cover.
  17. Support the cover on a flat work surface with wooden blocks (Removing Seal from Cover), and using a suitable punch and hammer, drive the old seal out of the cover from the back side of the cover to the front side(Removing Seal from Cover).
Apr 10, 2014 | 2004 Dodge Ram 2500
Hi, My three year old DV8396EA is overheating within minutes of boot; the rather noisy fan starting almost immediately. Core Temp meter, which previously gave readings of about 50 to 60 degs, now reads...
You are receiving temperatures that would be considered dangerously high for the internal components of your laptop. What i would suggest doing is opening up your laptop, if you are comfortable doing so, and inspecting the heatsinks, fans, along the chassis of the laptop, under the keyboard, and anywhere that there may be dust. Clean off all the dust with a good spay with a can of compressed air and try again. If your temps are still that high I would suggest redoing the thermal paste under the heatsinks in your laptop. Not having a good application at the factory can cause issues later on down the line. I use artic silver for my thermal paste. All you have to do is follow all the instructions that come with the paste and it should be alright. If you do not see your temps go down after that, I would suggest taking your laptop in for service as there could be a potential of damaging your internal components.
Aug 19, 2011 | HEWLETT-PACKARD Pavilion DV8396EA Laptop...
I have 2goodmanGKS9 gas furnaces(propane) installed on 27 Dec 2009. Both units are working. One is in the basement adjacent to the rear outside wall. Lower unit heats about 1200 square feet. Lower...
well lets start with the 2" pvc pipe. that is a combustion air intake it does not put air into the room, i hope. this is a 90% furnace and they should have installed it that way. there should be 2 pipes to the outside the other is combustion gases. the dust problem maybe caused by the air return pulling the air to that room. the bedroom normaly does not get the trafic that the rest of the condo does.so it would not have as much dust.
Feb 10, 2011 | Goodman Heating & Cooling
I just bought this 1998 Taurus and it is overheating. I assumed it was a bad thermostat, so I went looking for it to replace it. It took me forever to find what I believe to be the housing under the...
Hi!
The thermostat is located on top of the engine, follow the LOWER RADIATOR HOSE to the engine, the part where it connects to, is the thermostat housing, remove it to get to the thermostat.
Do the Cooling Fan kicks in when the temp. gauge is about half way up?? If not, check the Cooling Fan fuse(s) and Relay(s), they are located on the engine compartment Fuse Block.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 10, 2011 | 1998 Ford Taurus
We have a side by side samsung fridge/freezer. The freezer is working fine but the fridge is up to 60. We pulled the fridge away from the wall and cleaned underneath and also removed the grate in the...
One of the biggest problems is with the new refrigerants (R134A in this case). If the unit gets overheated it actually causes the salts in the moisture releases and travels throughout the system eventually clogging the metering device (capillary tube). The only thing that can be done is to have the system flushed, new drier, evacuated and re-charged.
Then make sure there is enough air circulating and keep the coils squeaky clean.
Nov 29, 2010 | Refrigerators
How to remove the front panel holding the air louvers...
We have a FAC127P1A and if you gently pull the lower cover by holding each side where there is an indentation it will lower so you can get to the filter. Then either replace or wash the filter. We have another model, FAA087P7A1, and we were able to pull the cover down and lift up slightly and remove the cover and wash to remove the collection of dust, etc.
On this latter model there is a collection of dust, etc. in the area where the cooling is blown into the room that I would like to know how to remove for cleaning. I feel it is unhealthy the way it is now and would like to clean it before removing for the season. I know I could use q-tips or a small piece of cloth to clean but that is pain staking.
Any help would be appreciated. Thanks.
Aug 28, 2010 | Frigidaire FAC126P1 wall/window Air...
I have a Kitchenaide side by side refrigerator thats not cooling.
Check the coils underneath the fridge. Check the coils in back if accessible. Clean the coils if covered in excessive dust it may help. Make sure the vent on fridge side isn't blocked or plugged.
Nov 28, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
KitchenAid Side by Side Refrigerator
hi thanks for the question is the compressor running . pull away from the wall remove back cover and check the compressor if its hot and running with no cooling you have a failed compressor thanks the appliance doc
Sep 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Franklin Industries FWC35 Compact Wine Cooler Side by Side Logo
405 people viewed this question
Top Franklin Industries Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Franklin Industries Furniture Expert? Answer questions, earn points and help others
