Question about Ovens
My Oven won't work on my tricity princess cooker
  • 60 Answers
Check the ement if thats not the problem it may be internal. You may have to call a technician.
Cheers
Allen
Posted on Sep 11, 2009
Manual for tricity contessa cooker, double oven and grill with slow cooker button. Just brought this reconditioned cooker, but it hasnt got a manual and I need one. I can't get the oven to turn on, it...
i have a vey old tricity contesssa cooker(which i love!)
The rings are heating but the oven and grill have stopped working,any suggestions on how to fix please??
Oct 08, 2011 | Ovens
Thermostatic switch fo 30 year old tricity marquis double oven the oven heats up but the temperature control does not work.
More than likely a faulty thermostat, I doubt you would get a replacement for a cooker of that age.
I would recommend that you seriousyl think of replacing the cooker.
Dec 09, 2010 | Ovens
Fan oven stopped heating
Is the fan working in the oven if not then check if the clock needs resetting.If the fan is working then it is more likely that the ring element around the fan has failed.Check also if the thermostat light comes on,this is an indication it may be ok.
Hope this helps.
May 25, 2010 | Ovens
Need a new main oven door spring
You can get a new spring from Airedale Springs Telephone - 0845 4754201
Apr 20, 2010 | Ovens
How do I change the fan oven thermostat on cooker Tricity Bendix SIE 531 TCGR
These will give you the basics
1 How to change a fan oven element and How to change a cooker oven fan Motor
2 How to fit a New Thermostat to a Cooker or Oven
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
3. If you have the opposite problem i.e. your oven is over heating and burning everything then you will need to replace your oven
thermostat
Mar 04, 2010 | Ovens
Tricity Bendix SIE504W oven overheating
I have had a similar problem in that the top oven was overheating getting hotter and hotter and have just got a replacement thermostat from Partmaster.co.uk. This is to fit a Tricity Bendix from Currys model number DSIE520 GR. The new one seems just like yours in that it has three lettered connectors A,B and C. With the part came a sheet stating that for a free standing appliance with NO timer (this what my cooker is) the connections to be made are : 2 on old part to A on new; F on old to B on new; G/H on old to C on new and the link from G/H and 6 on old to be removed or "severed". I haven't yet done this as its in my cottage which I'm going to this weekend. Good luck! James
Aug 11, 2009 | Electrolux Ovens
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Ovens
My tricity bendix electric cooker/oven trips all electrics
H iyou can get the electrics cheched that will rule that out but it sounds like a short on the oven it could well be the element in the oven which you should be able to replace as its only 3 years old
Jan 07, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Apr 07, 2008 | Ovens
Ovens Logo
108 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
