Question about Canon PIXMA MP780 All-In-One InkJet Printer
Fax Good day, I have asked my tel company to set a fax line, which they did. I think I have program it properly, I can send fax and they do get to destination, but I cannot receive any. it is like the fax does not get the in receiver. I have program it for 2 ringing tones I can see on the screen that someone is trying to send but the fax does not answer. please help suzanne ouellet
  • 2,427 Answers
Did you specify a destination to save the fax to ?
follow your user manual for instructions on how to do it propperly
The problem is in your configuration double check it
if you are still getting problems download and use winfax its fast easy and works
Posted on Dec 31, 2007
How to send regular fax from a bizhub c250
fax line connected to a analog phone line can not be digital, is the fax line plug, phone line good call it and problem or nise.ed into the line connector not the tel connector fax kit installed properly and set up correctly
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Apr 02, 2014 | Konica Minolta bizhub C250 All-In-One...
How do i send fax from bizhub 250
Fax line connected to a analog phone line can not be digital, is the fax line plug, phone line good call it and problem or nise.ed into the line connector not the tel connector fax kit installed properly and set up correctly
try this site
Apr 02, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Good day! I have a Canon MX-328. I was expecting to receive a fax so I read the manual and I set my printer to Tel priority mode since we only have one phone line mostly for voice calls. According to...
You have explained your question with very good detail
Press the colour button, then hang up. Most faxes are capable of transmitting colour faxes, and you should press the colour because even if the sender sends a B&W Fax, it will Automatically receive it in B&W. If they send a colour fax and you hit the B&W Button, it will only receive in B&W.
I hope this helps, if so please rate this answer below Thank You for supporting the FixYa Community
Regards GM
Apr 25, 2011 | Canon PIXMA MX300 All-in-One Printer
Can not receive or send fax. There is the phone tone on the BT line.
When we are speaking about faxes you have to try at least a few numbers, because there is sometimes a temporary problems with tel line speed. To send or receive the fax the tel line should be stable. Fax machine try to connect to highest speed (33,6 by default) and if the line is not stable you will receive connection error.
Try again but tomorrow or ask yout telephone company if there is a problem with line
Feb 20, 2011 | Samsung SF-5100 Plain Paper Laser Fax
We have two fax machines hook up to one dedicated fax line. When we send a fax from wither machine it is not faxing to the phone we fax it only sends the fax for the second fax machine that is in our...
Yes, you must set up your fax machines like this: The receiving fax must be set to auto receive and the telephone line must be inserted in the "line" input. A line must then be connected from the "Tel" to the "Line" of the Transmitting machine, which must be set to "manual receive." This is not really a satisfactory way of doing things as you can't send and receive 2 machines on the same line together. A much better way is to have 2 lines. with a machine attached to each. Get the tel company to put "No answer transfer" on the line as an accesory. Give them the number of the fax machine that transmits. Make it "manual receive" Now you have a versatile system that you can also use the office telephone with.
Oct 05, 2010 | Brother Office Equipment & Supplies
I can send faxes but can not get a fax. It rings and does not pick up. I have it set for two rings. Hp 6128. I called the phone company and they said if it can send faxes there is nothing wrong with the...
May 13, 2010 | Office Equipment & Supplies
I believe I have somehow "lost" the ability to send a fax. All it does is ring and then make the fax noise like it is picking up, but then the message will say, "TELEPHONE". and absolutely nothing will...
sounds like you have the fax set to tel mode or the cable is in the wrong connector check the entry point for the fax cable that it is in the line socket and not the tel socket also check that when you are sending the fax that it says load document as it might not be getting the paper set correctly so thinks you are doing a tel call.. good luck A
Jun 29, 2009 | Brother IntelliFax-1860C Plain Paper...
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
For use with a dedicated fax line.
Every call is answered as a fax.
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Receiving and sending faxes
if the fax is connected to the same line and you have a phone connected to the fax you need to make sure you connect the line from the socket at wall to the correct socket on the fax you can check this by looking at the point the line is connected on fax there should be two connectors one says line and one says tel.. the line in goes to the line socket and your telephone goes into the tel socket.. if you have them the other way round it cant connect properly..on the front display panel make sure you have it set to the auto setting or tel fax mode for receive.. if you have it to auto it will check the incoming call if it is a fax it will send it through if not it will ring till you answer.. if set to tel/fax mode when it rings you will have to answer the phone and manually press start if you hear it is a fax.. Good luck A
Mar 04, 2009 | OKIFAX 4580 Plain Paper LED Fax
Not receiving faxes
So if you have no noise, its a prob of the tele company not of the mfc!
Or did the tel company change to another tel standard instead of your former type?
You have to talk to the tel company to get that clear. Ask for the line standard bein g used (ISDN, normal, or a special tcpIp).
When you got the info call brother hotline of your country for support. They will help you with that prob.
Jan 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
66 people viewed this question
old marine
old marine
