Question about Estate TEDX640JQ Electric Dryer
How do i replace belt on my estate whirlpool dryer?
    President:
  • 1,776 Answers
Check out the video at the link I am providing. It should assist you in the belt replacement. Sure hope so anyway! Hope this helped and best wishes.
http://www.youtube.com/watch?v=9dd1Ac4_pXY
Posted on Sep 11, 2009
Belt replacement
This article I wrote will assist you to replace the belt
How Replace The Belt on Your Whirlpool Dryer
Your dryer is made by whirlpool and this is how to replace the belt
Jan 30, 2014 | Estate TEDS840JQ Electric Dryer
Dryer will run and heat but will not turn
It sounds like your drive belt might be broken you can get a new one if you go to www.repairclinic.com enter in your model number and it should cost around 9$ the other possibility is the tension pulley or if it doesn't sound like your motor is running but most likely the drive belt .
Nov 24, 2012 | Estate by Whirlpool EED4400WQ Estate 29in...
I need to replace the belt on my Estate dryer. How do I get to the belt?
Generally speaking on front load whirlpool dryers the belt can be accessed from the rear by removing the back panel. Good luck.
Dec 13, 2011 | Estate Dryers
My Whirlpool Gas Dryer Estate Model # TGDS680BW1 will not tumble when I turn it on but the motor still runs. How can I fix it?
The problem is likely the dryer belt . Here is a video on replacing a dryer belt. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Sep 17, 2010 | Estate Dryers
Belt on my Whirlpool dryer, Model # LG5201XTWO is broken.
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Estate TEDS840JQ Electric Dryer
The dryer will get hot but the drum will not go around
More than likely, the belt is broken. Otherwise, the drum motor is shot. (That's not very likely though).
Apr 22, 2009 | Whirlpool LGR5636L Gas Dryer
My whirlpool estate dryer tub will not rotate
To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 | Estate EED4300SQ Dryer
which pulley came off the one on the motor, or the Idler wheel that keeps tension on the belt. You probably will need a belt
May 26, 2008 | Estate TGDS840JQ Gas Dryer
Estate TEDX640JQ Electric Dryer Logo
151 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
