Question about Solis SCDIG-5000 Coffee Maker, Espresso Machine
Brew unit blocked
i get the brew unit blocked error
switched off and on power, machine was ok again.
used the machine for 3 cups
this morning same thing, brew unit blocked
switched on and off power, still brew unit blocked
also brew unit is hard to take out
  • jimjam65 Dec 27, 2008
    yep. sadly have the same prob with my 5000 digital.i have pulled the whole guts out 4-5 times cleaning everything and still have no solution to the problem.any assistance would be great thanks. james
  • Anonymous Feb 24, 2009
    Same problem, but the inner mechanism sounds slow in its routine of strange noises so it sounds like a mechanical fault and nothing to do with the brew unit itself (though I could be wrong.)
    I have cleaned the brew unit to within an inch of its life and still no joy. Last time I had a boiler problem it cost £300 to fix by Coffetech (in Redbridge I think.)
    Looks like the knackers yard for the Solis this time - the wife is already getting jumpy!
I cannot get the brewer back into place of my miele cm5100. What do I do?
According to page 66 of the manual, "The brew unit or the brew unit motor is not in the correct position."
1. Turn the unit off with the power button.
2. Press the smaller cup & larger cup buttons simultaneously. Then press the OK button twice.
(This will initialize the brew unit motor and the brew unit will move into the start position.)
3. If the brew unit can still not be removed or replaced in the machine, contact the Miele Technical Service Department (800) 999-1360 [Monday-Friday 8AM-8PM EST].
Feb 25, 2015 | Miele Coffee Makers & Espresso Machines
Keurig B31 jammed up.~ come up with some tips
Thanks for the tip received that was actually not listed in the the Keurig's user manual.
This morning I encountered my slightly over one month (Dec 2013) old Keurig Mini B31 jammed up, I was only used 3 times so far...:( and feeling quite frustrated after wasted all 3 K-cups to try and find out what went wrong, initially thought it did not punch the hold properly, but still only a few drops of coffee came out from the brew, everything thing seems to work fine, it was just no hot water flowing down.
Tried to clean up K cup bottom needle with clip, but does not help, after browsing though fixya found that the top part needle also really need to clean up (not stated in the user manual), by using paper clips and finally it works again after all the dirt came out from the top part of hold puncher. My tips for people who did not use it daily /very often, they should:
  • Clean up the top needle by running through a cup of water to flow it through the ground coffee excess after each brew was completed, otherwise it will tend to dried up and choke up before you know it.
  • It help to shake it cup to have the top of the cup fill with some air, and it has less tendency to have the ground coffee in block up the top needle.
Hope this tips will help you to maintain a good cuppa!
on Feb 10, 2014 | Keurig B31
"brew unit block" medium cup in service mode dont work only the small cup works
When the alert came up- Brew unit blocked- this is before you started taking things apart, A, were you able to remove brew unit, Yes or No?
B, after turning power on and then off, Did the machine try to reset brew unit to home position Yes or no?
If Yes were you able to remove brew unit?
Aug 18, 2014 | Miele CVA615 Espresso Machine
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Brew Unit Blocked
open the door and see small screw in the middle of the brew unit. Take it off with small screwdrive and pull out the brew unit.Then put the small thing (something like a pipe) to the brew unit with the small screw. Then without brew unit in the machine press the switch inside the machine where stayin the brew unit and the switch witch is stayin the top of door .Switch on the machine and wait while self test is making,then put the brew unit in the machine and that it.Enjoy!
If you have any question -ask me.
Nov 25, 2013 | Saeco Royal Professional Espresso Machine
My new Breville Keurig machine randomly turns off. I noticed a few times it was right after brewing a cup and it's about to uptake more water or it's in the process of taking up water and heating it. Has...
I just tried the solution from comment dated 1/13/10. I took out the water tank and reseated it. As I did that, I noticed a small gap at the top back of the tank, that it wasn't resting completely against the unit well. I pushed it back and it has not shut off since.
Dec 09, 2009 | Breville BKC600XL Coffee Maker
After getting Replace Water Filter VEntilate display I replaced with Saeco Intenza water filter cartridge I have always used. However, unit does not move off this display after I press OK button. I have...
After replacing the filter in the tank, keep the button pressed; when the indicator light is flashing, then release the button.
Also at times, the gears in the brew drive assembly will not complete the cycle to the proper start position for different reasons. Some of the reasons are:
  1. Brew group jammed or blocked.
    Note: A jammed or blocked brew group can happen when the brew group starts the cycle but doesn’t finish it.
  2. Either one of the micro-switches in the brew drive has gone bad.
  3. Brew drive motor failure.
  4. Broken teeth on either of the brew drive gears.
  5. Dirty brew group, covered by coffee grinds.
  6. Brew group or gears not lubricated.
  7. Connections to the board from brew drive assy., or motor have gone bad
Oct 08, 2009 | Saeco Incanto Classic Espresso Machine
My machine only brews 1/2 cup of coffee. I have de-scaled twice within the last week and I get a full cup of vinegar/water, but as soon as I put in a K-cup I only get 1/2 cup of coffee out. The first cup...
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Aug 15, 2009 | Keurig B60 Coffee Maker
Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Jun 03, 2009 | Saeco Easy Espresso Machine
Opened the grounds cup while machine powering on, now it's blocked
Here's the deal.
1. As you've probably learned by now, don't take anything from teh machine when its powering up and even when its going threw a brew cycle.
Here's whats happened, There's a set of microswitches that connect to the main board on the unit. One of the switches is triggered by the grounds cup.
When one of the switches is set off the unit goes into alarm and locks down.
Now to your problem. When the machine starts up its just like a brew cycle. The machine goes threw a Test mode of sorts where its checking the brew drive.
Once you pulled the ground cup, i'm almost 100% positive (its a common problem) that you set the alarm off mid cycle and jammed the brew group in place.
Since the brew group switch and the ground cup switch are so close together, it basically jams them both per say.
So basically unjam the brew drive to its original position is the only way to fix the problem.
Option 1: 2 tiny screw drivers. Turn the machine on. By the brew drive there's should be 2 holes where there's little metal clips stick out. When you press them with the screw drivers, the machine will trigger the brew drive back to the original settings.
Option 2: Flat head screw driver. where the grounds cup is there should be a little slice on the machine. turn machine on. place screwdriver there, brew drive should go threw test and then back to original position. Once everything stops, you should be good to go.
Option 3: Sent out for service. Worst case scenario.
Don't use alot of pressure as these pieces are all aluminum and plastic.
Wish ya the best of luck.
Mar 27, 2008 | Saeco Magic De Luxe Espresso Machine
Solis SCDIG-5000 Coffee Maker, Espresso Machine Logo
41 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
