Question about Lexmark X1270 All-In-One InkJet Printer
My X1270 only prints pink on the best setting?
This is a new Lexmark Black 17 Print cartridge.
My Lexmark X1270 printer at one time worked, everything was good, then when I put a new color to black will not print any other color or a black color, print only a little pale, almost do not see anything...
Lexmark products work best with genuine supplies. Lexmark does not recommend the use of refilled, remanufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
You can try to clean your cartridge nozzles using the Lexmark software on your computer. From your computer, go to Start menu > Programs > Lexmark X1200 Series folder > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If that does not help, maybe it would be best to replace your supplies with genuine cartridges.
I hope this helps.
Dec 02, 2011 | Lexmark X1270 All-In-One InkJet Printer
I just bought 2 new catridges (black & color) but the color ink dosen't print.
I'm not familiar with Lexmark but I think your printer is set only to print on black cartridge (black only option) There's something wrong with the settings. Check the settings, look for the color options.
May 16, 2011 | Lexmark X1270 All-In-One InkJet Printer
Can a no.16 print cartridge be used on this printer?
Yes. #16 black cartridge is compatible with Lexmark X1270 printer. Other compatible cartridges are: #17 (black), #26 (color) and #27 (color). Hope this helps.
Jul 18, 2010 | Lexmark X1270 All-In-One InkJet Printer
Some time it prints in pink
Do you see the color cartridge icon in the progress window being low ?. Or do you get an low ink warning dialog when you print a job. First try cleaning the cartridges if that doesnt help, you may need to replace your color cartridge.
See the below link for cleaning your cartridges, the procedure is near the end of the page:
http://support.lexmark.com:80/perl/support/support.cgi?relevance=0&ccs=229:1:0:537:0:0&mode=DOCS&doctype=KB&term=clean&docid=ENUS30978
Jun 01, 2009 | Lexmark X1270 All-In-One InkJet Printer
Black will not print properly
your cartridge is about 100 pages of ink. Try to buy #16 black and #26 color for best results and economy, since #16 have about 250 pages resource.
Mar 07, 2009 | Lexmark X1270 All-In-One InkJet Printer
Help - Black not printing
Try cleaning the contact points of the cartridge itself and the unit that holds the cartridge with alchol. If still not printing try nossle cleaning from your printer properties.
Mar 27, 2008 | Lexmark X1270 All-In-One InkJet Printer
My Lexmarkx1270 will not print any black text etc
Is it a new cartridge? If the cartridge has been sitting a while it can get clogged. Try using a moist paper towel and gently wiping the cartridge where the ink comes out.
You could also try running the Lexmark Solutions Center program and use the clean nozzles option to force it to squirt out some black ink.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark black cartridge-and printer x1270 not printing black
I have a lexmark 6570 with similar problem. Who can help?
Nov 08, 2007 | Lexmark Inkjet Z517 Photo Printer
Lexmark X1270 All-In-One InkJet Printer Logo
61 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
