Question about LG LRSC-26922 Side by Side Refrigerator
Water/ice dispenser sticking on
We are having a problem with the We are having a problem with the water/ice dispenser sticking on our LG Refrigerator. It has happened a few times in the past when I would get water and it would get stuck and keep dispensing water. I kept pressing the back panel until it finally stopped. I tried to get water the other evening and it is now stuck and continues to dispense water. I finally got it to stop by opening the freezer door but once closed it would start again. I pressed the lock button on the panel which caused it to stop but the light stayed on because it was still in the “dispense mode” so I unscrewed the lightbulb. Once I unlock the water continues to dispense? Any idea as to how to fix this? on our LG Refrigerator. It has happened a few times in the past when I would get water and it would get stuck and keep dispensing water. I kept pressing the back panel until it finally stopped. I tried to get water the other evening and it is now stuck and continues to dispense water. I finally got it to stop by opening the freezer door but once closed it would start again. I pressed the lock button on the panel which caused it to stop but the light stayed on because it was still in the “dispense mode” so I unscrewed the lightbulb. Once I unlock the water continues to dispense? Any idea as to how to fix this?
We had a problem with the water/ice dispenser on our 5-year-old LG SxS Refrigerator (LRSC 26930TT). In a panic to stop the water flow, the rubber activator boot was pulled off. The dispenser stopped once the button attached to the back of the boot was removed. Nothing was physically broken (i.e., parts intact) but the challenge was to get things (especially the boot) back in place. The key for me was to use patience: researched Internet for pointers (not too helpful), looked for schematics (even less fruitful) and exhaustively examined the panel on refrigerator (to help reverse engineer). Okay, here’s how I disassembled and reassembled without breaking any tabs or other pieces. Assuming your unit is similar, the panel is on the freezer door on the left side. You can lock the dispenser (using panel button) to preclude undesired water/ice while working. Note: the outer bezel (edge of panel) is secured by screws and should not be messed with. The main panel has tabs on all four sides. I used three screwdrivers (small to average in size) to pry the panel off. Pry the main panel working through the seam between the bezel and panel. Work your way around starting from the lower left or upper left corner. Each side of the panel has 3 or 4 tabs. Methodically work your way around using moderate force to pop the tabs loose. Once the panel is loose, you’ll need to disconnect the electrical connector at the upper left. The plug comes off and reattaches easily…don’t pull on the wires, use the plastic connector itself. Wiggle the panel free. Now you can get to the back of the boot retention bezel…the ultimate goal. Carefully push the bezel’s securing tabs (x3) through the panel and reattach the rubber boot. I used needle nose pliers to carefully pull each rubber nib through their applicable hole on the bezel. Now leave the boot/bezel assembly to the side—it’s the last step to reassembly. Note how the main panel tabs fit into their receiving slots/flanges. Reattach the electrical connector, snaps right on, and maneuver center of panel into recessed area, around ice chute/water nozzle. Slide the right and bottom sides on first—flanges, not slots for tabs—then align remainder of panel. Using moderate force, pop (punch) the remaining tabs back into their respective slots. The main panel will seat over the bezel. Now align and snap boot/bezel back into place. Finis! (No guarantees, but this procedure worked like a charm for me.)
Posted on Mar 14, 2010
  • karenwith3 Sep 25, 2010
    Thanks so much for this instruction! I too have looked everywhere and this was the best info I've gotten. I (43 year old woman) just deinstalled the dispenser and replaced the display assembly frame so that I could install the newly designed funnel cone. Thanks again...without this, I might have called a repairman for this fix!
  • 65 Answers
The switch behind the Lever is sticking. You will probably have to replace the switch.
Posted on Sep 11, 2009
Water dispenser in door does not dispense
Had this happen on my LG side-by-side a few years back. It's a common part. Find the version for your make and model. Easy ti replace. It is located where the water suppy connects to the bottm refridge.
http://www.amazon.com/LG-Electronics-MJX41178908-Refrigerator-Water/dp/B00AUDAJ0I
Oct 25, 2015 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
LG REFRIGERATOR DISPENSER NOT WORKING
x1 sonny ericcson widows mobile 6.1 version i want to change my language to english
Jan 05, 2014 | LG LSC26905TT Side by Side Refrigerator
Whirlpool side by side, water-ice through the door. Icemaker and ice dispenser works fine, water dispenser does not. What could be wrong?
I think the solenoid that operates the water on and off is bad. After awhile calcium deposit builds up around the plunger causing it to stick. That's what happened with my refrigerator. Hope This Helps.
Oct 02, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
LG fridge LRSC26915SW -= water dispenser and ice are not getting water
Replace water filter, this unit had a issue with restrictions in filter due to a design issue. Water valve is all so called a water pump from many people.
Aug 17, 2012 | LG LRSC26915SW 36" Side-by-Side...
LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Mar 21, 2010 | LG LRSC-26922 Side by Side Refrigerator
Stuck Water/Ice Dispenser LG LRSC26920TT
THE ACTUAL BUTTON AND ACTUATOR NEEDS CHANGING AND POSSIBLY THE SWITCH. EARLIER MODELS WERE CHANGED BECAUSE OF THIS.
Aug 18, 2009 | LG LRSC-26922 Side by Side Refrigerator
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Mar 21, 2009 | LG LRSC26910 Side by Side Refrigerator
In door ice and water dispensing
sounds like the paddle is hanging up or the micro switch that the paddle actuates is sticking if you can see the micro switch spray some wd 40 on it open the door and work the paddle a few times
Feb 15, 2008 | Frigidaire FSC23F7D Side by Side...
LG LRSC-26922 Side by Side Refrigerator Logo
1,655 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
