Question about Frigidaire Affinity ATF7000E Front Load Washer
Washer won't spin
Hello. My front loading washing machine is about 4 years old. Today, it stopped spinning the laundry. It gets all the way to the final rinse, drains the water and then, just shuts off without spinning. Please help!
    Problem Solver:
  • 14 Answers
Check to see if the strainer before the pump is partially clogged.
Posted on Sep 11, 2009
Fridgidare washer front load won't spin & there's water in the tub. It's about 10 years old
If it's that old, you're better off buying a new unit. You'll spend about half the cost of a new one fixing it.
Jun 11, 2012 | Washing Machines
Whirlpool wtw5tesvno
Hello.
Whirlpool washers are available in many colors and with different options, including various tub sizes, front or top load styles, a fabric care system, high efficiency wash features and energy, time and water sensors. The washers may be purchased in department stores, home repair stores and online. Many are Energy Star rated. However, the washing machine may malfunction occasionally and not agitate or spin. If this occurs, some troubleshooting steps may be useful in solving the problem.
1 sure the washer has electrical power and is connected to a grounded electrical supply. Replace or reset the circuit breaker or fuse if needed, particularly in event of a recent power outage. Make sure the washer lid is closed tightly before use; the washer won't work if the lid is open.
2 void selecting the following cycles: "Extra Low,, "Low," "No Spin", "Delicate," "Casual/Perm Press" or "Hand Washables." All of these cycles use little to no spinning or agitating during the cycle. Select the highest possible spin cycle for the fabrics being washed.
3 pen the washer lid and redistribute the load; unbalanced loads may cause the washer to stop or slow down. Add additional items if only one large item,
such as a rug or blanket, is in the washer.
4 Use only the recommended amount of laundry detergent, as excess sussing can reduce the overall spin speed or cause the washer to stop agitating. If the Whirlpool washer is a high-efficiency model, use only high-efficiency laundry detergent.
5 Examine the drain hose and straighten if kinked. Remove any possible obstructions and ensure the end of the hose is no more than 96 inches from the floor, as this will cause water to flow back into the washing machine.
Thanks.
Nov 13, 2011 | Whirlpool Washing Machines
Washer won't spin. 2 years old.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 07, 2011 | Kitchen Ranges
When doing a load of laundry the washer will stop at the rinse cycle and not drain or spin out the excess water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 03, 2011 | Frigidaire Affinity ATF6000F Front Load...
I have a 4 year old Kemore HE2 that isn't spinning the water out of the clothes. I encountered this issue about a month ago and found a fix for cleaning out the hidden pump trap. After removing a large...
heatman101
Sep 07, 2010 | Kenmore HE2 Plus Front Load Washer
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
Sep 28, 2009 | LG WM-2277HW Front Load Washer
Hi, many times my wash load does not spin properly and it is still very wet / need to put it on spin cycle again before drying. Also sometimes does not use the liquid fabric softner along with not properly...
Hello. Have you checked the speed settings on the control panel? There are alsways some sort of speed settings on any washing machine these days. It starts from 500rpm, 700, 800 and 1000 rpm. My Fisher machine spins up to 1000 rpm. Surely there must be some settings in your machine. If not, how old is the machine? If it is a cople of years old, you can contact the retailer and find out about it. But if it is several years old, then best if you solve this with a local repairer. Otherwise a new one would do you better, and less worries, too
Sep 23, 2009 | GE Washing Machines
LG front load washing machine will not spin
I am having the same problem with my washer. Go to this web site below it has a free troubleshooting guide. I narrowed my washer machine down to two parts. Stator assy or Main PWB assy.
http://136.166.4.200/contents/Laundry/WM2042/WM2042xx_Service_Manual.pdf
Oct 10, 2008 | LG WM-1832C Front Load Washer
No final spin
is there stil standing water in the unit at the end??
Jan 26, 2008 | Frigidaire GLTF530DS Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
156 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
